Engel bad vibrations
Submitted: Sunday, Nov 30, 2008 at 14:49
Muddie
My Engel combi gets a noisy harmonic vibration set off by a bump and might run for 4-5 mins and stop again from another bump then start again. When I pull up and its still going strong, a power off and on stops it, any ideas.
thanks David
Reply By: sdtash - Sunday, Nov 30, 2008 at 15:23
My engal gets a noisy hum up every now and then. Kind of like it has a leaf caught in a fan. Been ding that for years now! Still works fine though. Personally I would not worry about it.
Shane
337546
Follow Up By: Muddie - Sunday, Nov 30, 2008 at 15:40
No this is loud and gives you the #h!ts, as if the compressor mount is busted, but its not
605156
Follow Up By: Goona - Sunday, Nov 30, 2008 at 17:56
Mine does the same and it to has been running for anout 7 years no dramas
605174
Reply By: Member - Ed. C. (QLD) - Sunday, Nov 30, 2008 at 17:24
Check the compressor cooling fan..
Mine was doing something similar to what you described ('fridge was still working fine), and it turned out that said fan had sh@t itself (collapsed bearings)..
repair bloke said that apparently there'd been a bad batch of these fans, as he'd replaced a few...
replaced under warranty (approx 3 yrs ago), and it's been fine since.....
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
337559
Reply By: Member - Leigh (Vic) - Monday, Dec 01, 2008 at 08:56
There was an earlier post on this and it seemed the rubber mounts on the compressor were a good place to start. Seemingly an easy fix?
337637
