Whatever happened to Ozi?
Submitted: Thursday, Aug 07, 2003 at 14:32
ThreadID: 6423 Views:2710 Replies:8 FollowUps:13
Searching back throught he archives for info on long range tank manufacturers I noticed numerous, quite vociferous, postings by someone named oziexplorer. This forumite seems to have vanished into thin air. Whatever happened to Ozi?"Live today as if there may be no tomorrow"
Wombat
Reply By: bruce - Thursday, Aug 07, 2003 at 14:55
I think he has been about...uses different names...but uses the same style....easy to pick...usually bagging someone for not using the same gear as him...harmless , but probably does know a bit..pity he cant use his knowledge a bit more constructively instead of critisising..thats my opimion for what its worth (if anything )...cheers
AnswerID: 27038
Follow Up By: Member - Wombat (Vic) - Friday, Aug 08, 2003 at 12:18
Any idea what names he has been using, Bruce?"Live today as if there may be no tomorrow"
Wombat
FollowupID: 18634
Reply By: Squid - Thursday, Aug 07, 2003 at 15:02
He can occasionally be found on the overlander forum. These days he does not seem to be as vociferous (I had to look that one up in the dictionary).
If you ignored his vociferousness (I'm getting carried away now) he actually had some worthwhile comments and I found his information very helpful.
AnswerID: 27039
Reply By: Member - Willem- Thursday, Aug 07, 2003 at 15:13
Hi Wombat,
I think it was somewhere in January nor February when Ozi declared that he was leaving the forum as he was being given too much stick from some of the other partcipants in this forum. He was a knowledgible fella but always answered a question with a question which drove some people insane.
I have a tank manufactured by Brown Davies, I think. They are in Melbourne.
Look forward to catching up with you at the end of the month.
Cheers, Willem
Never a dull moment
AnswerID: 27040
Follow Up By: Member - Wombat (Vic) - Friday, Aug 08, 2003 at 12:21
If you don't mind I'll pump you for some info on the Brown Davies when we catch up. We're looking forward to it. Sounds like a few people miss Ozi - I wonder what upset him enough to just up and leave?"Live today as if there may be no tomorrow"
Wombat
FollowupID: 18636
Follow Up By: Member - Bonz (Vic) - Friday, Aug 08, 2003 at 20:10
Brown Davies ar in Meelb out the east side, good guys, Great Mechanics,excellent LR tanxSo many places to go!
So much work to do :0(
FollowupID: 18667
Reply By: Truckster (Vic) - Thursday, Aug 07, 2003 at 15:16
He was run out of town... Like a fart in the wind thankfully...
But hes still here, Virtual bullets dont work. He has around 4 different names, me and Ray were discussing it one day, we figured out 4 of them!
AnswerID: 27041
Follow Up By: Member - Wombat (Vic) - Friday, Aug 08, 2003 at 12:23
Sounds like you don't miss him at all Bruce! Could you enlighten us with the four names you and Ray came up with?"Live today as if there may be no tomorrow"
Wombat
FollowupID: 18637
Follow Up By: bruce - Saturday, Aug 09, 2003 at 10:50
No , no idea what name or names he is using now , could be using anything even Wombat....who knows ? ..or cares , at least I am not afraid to use my real name...cheers
FollowupID: 18715
Reply By: Leroy - Thursday, Aug 07, 2003 at 15:27
Hi Wombat,
I bought my Redarc battt isolator through him and he was quite helpful. I think he's on holidays at the moment.
About your tank, I got mine from Long Range Automotive in Lilydale. Reasonable happy with it. It seems to hang down a little lower that the stock tank but I didn't reaise they will build to your specs. I think if I was to do it again I would have the front of the tank height say 30mm shorter so the bottom of the tank falls towards the rear....if that makes any sense.
Leroy
AnswerID: 27044
Follow Up By: Member - Wombat (Vic) - Friday, Aug 08, 2003 at 12:31
Hi Leroy,
So he was a fellow Victorian? I got a quote from Long Ranger but am having trouble trying to justify over $1000 for something which will, in all probability, only be necessary a half dozen times.
Mustn't be long now till you head off?"Live today as if there may be no tomorrow"
Wombat
FollowupID: 18638
Reply By: REXY - Thursday, Aug 07, 2003 at 15:42
hi wombat.....i got the 130 ltr fitted to my surf mobile from ARB about 9 months ago off the top of my head it cost about 1300 ish it is really good same filler point as the normal tank and it dosnt hang down under the chassie (spell check) and there is alittle bit off room left incase i wanna make up a water tank for it as well...b4 i went to arb i check out tjm and they informed me that NO ONE made tanks that big for surfs....so as always check around hope this helps
cheers rexy
AnswerID: 27046
Follow Up By: REXY - Thursday, Aug 07, 2003 at 15:43
ye gods im an idiot.....it would also (me thinks) help to mention that i had to get a suspension upgrade as well to handelthe extra weight ...obviouse i know but hey someone might not realise that
FollowupID: 18567
Reply By: Member - Al & Mrs Al (Vic) - Friday, Aug 08, 2003 at 12:39
Wombat it was probably words like 'vociferous' that cheezed him off...hahah
Spoke to Al about the LRT, but we;re going with std tank and using LPG as backup, can't replace the Std tank anyway, apparently, I got lost in the technical stuff the big guy was talking about. He's got the hydraulic legs for the van, and now is changing the suspension on the cruiser....!!
Is Avocado suprise ok for you on the 31st? (Or don't you want Willem to see your party trick....:)
Lyn [Mrs. Al]
PS The big fella said he's got your brackets...[I"m sure you know what that means"]1927 Oldsmobile Tourer
Corrugations...what are they?
AnswerID: 27154
Follow Up By: Member - Wombat (Vic) - Friday, Aug 08, 2003 at 12:49
It's like a never ending money pit, isn't it.
I might try to escape from the outlaws (visiting) this weekend to pick up the brackets and return the tandem.
So you think Ozi may have been a sesquipephobic?
You know where you can stick your avocado!"Live today as if there may be no tomorrow"
Wombat
FollowupID: 18639
Follow Up By: Member - Al & Mrs Al (Vic) - Friday, Aug 08, 2003 at 13:05
Now you've got me...what the hell is sesquipephobic? I can't even find it on Google...ehehheheh....
Should be fine, Al is working on something in the shed as per normal on Sunday, working on Saturday.
You're right about $$$$$$$$$$$$$$$$$$$
Did you workout your blackout curtain dilemma?
Avocado...!!!?? people will think you care..:)1927 Oldsmobile Tourer
FollowupID: 18644
Reply By: Member - Rohan K - Sunday, Aug 10, 2003 at 17:05
Wombat, if you really want to find him try here
overlanderSmile, you're on ExplorOz
Rohan (Sydney - on the QLD side of the Harbour Bridge)
AnswerID: 27352
Follow Up By: Member - Wombat (Vic) - Monday, Aug 11, 2003 at 11:52
Thanks Rohan,
I didn't really want to find him (he seems a little too self opinionated for my liking) but I was just wondering what had happened. Great to see you enjoyed your recent trip so much. Now to start planning for the next one hey?"Live today as if there may be no tomorrow"
Wombat
FollowupID: 18878
Follow Up By: Member - Rohan K - Monday, Aug 11, 2003 at 13:59
Yeah. Not sure what it will be now. Having been out-voted and going to Fraser in July, the plan was then to do Cameron Corner in October (reverse of what I wanted). Now the Mrs is faltering on that idea, so CC may have to wait to May/July next year. Oct. could just see a shorter trip out to Weddin NP and there-abouts, home via Dubbo Zoo.
Might do Tassie in January - only state I haven't been to yet.
Hmm. So many choices, so little time!Smile, you're on ExplorOz
FollowupID: 18890
Follow Up By: Member - Wombat (Vic) - Monday, Aug 11, 2003 at 14:38
IMHO January is the perfect time of year forTassie. We did it a couple of years back and can't wait to get back. We're doing Darling River - Cameron Corner - The Centre - Katherine next June/July with Mr and Mrs Al so we may cross paths and get to see that "One fine Pathie" in person."Live today as if there may be no tomorrow"
Wombat
FollowupID: 18891
Follow Up By: Member - Rohan K - Monday, Aug 11, 2003 at 15:11
You never know.
Hopefully by then it'll be even "finer".Smile, you're on ExplorOz
FollowupID: 18896
