Site Search
Section Image
Oils and Lubes Feedback
Submitted: Sunday, Dec 21, 2008 at 19:05
campervan
Article Overview - Oils and Lubes
Whether you drive an old or a new vehicle, oils and lubricants for your engine, diff and gearbox are critical factors affecting performance and also your running costs. View Full Article...
Hi I own a Toyota Rav 4 ACA33 Manual, petrol,2006 {new Model]. I have looked up the Penrite site to see what engine oil to use but they only have Rav`s listed to 2006 [ older model]. Does anybody know what Penrite oil to use for ACA33 manual or can recommend another oil brand?
ThreadID: 64465 Replies: 5
Views: 781 FollowUps: 9
AnswerID: 340818   Submitted: Sunday, Dec 21, 2008 at 19:58
toyocrusa replied:
Hi. If you have a look in the owners handbook,possibly under specifications or maintenance the oil spec should be shown. I think it should show 10/40 in which case it would be Penrite HPR 10, the same as the last few years petrol models. Regards, Bob.
Reply 1 of 5
FollowupID: 608456   Submitted: Sunday, Dec 21, 2008 at 20:12
campervan posted:
Hi Bob, Just checked engine lube specs 20w-50 and 15w-40
API grade SL or Sm multigrade engine oil.
Thanks,Annette
FollowUp 1 of 4
FollowupID: 608459   Submitted: Sunday, Dec 21, 2008 at 20:27
toyocrusa posted:
In that case HPR10 will be perfect for you.
FollowUp 2 of 4
FollowupID: 608461   Submitted: Sunday, Dec 21, 2008 at 20:33
campervan posted:
Thanks muchly
FollowUp 3 of 4
FollowupID: 608466   Submitted: Sunday, Dec 21, 2008 at 21:19
Member - Phil G (SA) posted:
Annette,
Have another look. In the Toyota manual, theres usually 3 options according to temperature. Nobody needs to use 20W50. The 15W40 is good for hot temps in northern Australia. For the rest of us a 10W30 or 5W30 seems to be the best option for a modern petrol motor, like your RAV.
The trend these days is to use thinner oils because modern engines use smaller oil channels and they lubricate quicker at startup. And you'll use a little less fuel with a the 5W30. I'm not a fan of Penrite oils - the viscosity when hot (the second number), is often thicker than the manufacturers recommendations.
Mt Finke
Click Image to Enlarge
LandCruiser HDJ79
FollowUp 4 of 4
AnswerID: 340820   Submitted: Sunday, Dec 21, 2008 at 20:10
campervan replied:
Hi Bob,
Just checked engune lube and it says 20w-50 and 15w-40
API grade SL or SM multigrade engine oil.
Thanks,
Annette
Reply 2 of 5
FollowupID: 608457   Submitted: Sunday, Dec 21, 2008 at 20:15
Member - Paul W (VIC) posted:
use a 10 or 15w40/50 and not a 20w,too thick for a modern petrol engine.you will have problems with starting and oil pressure problems when cold with a 20w oil,a 10w40 will do the job,if you dont mind spending a bit extra use a semi-synthetic.cheers Paul
1 of my 3 girls!
Cheers Paul
FollowUp 1 of 2
FollowupID: 608460   Submitted: Sunday, Dec 21, 2008 at 20:30
campervan posted:
Thanks Paul
FollowUp 2 of 2
AnswerID: 340835   Submitted: Sunday, Dec 21, 2008 at 22:11
Robnicko replied:
Campervan,
I have a 95 Landcruiser with the 4.5 petrol engine and have always used Penrite 30 (20w-60).
I have never had a problem and although it has a higher 'hot' rating I beleive this can only help the motor when it's under hotter extremes. I think the HPR15 semi synthetic would be fine. Why not send Penrite an email asking for reccomendations?
Rob
Reply 3 of 5
FollowupID: 608607   Submitted: Monday, Dec 22, 2008 at 20:49
20w60 sounds like sludge in a 1FZ-FE. Why use oil thats so thick?
Mt Finke
LandCruiser HDJ79
FollowUp 1 of 3
FollowupID: 608675   Submitted: Tuesday, Dec 23, 2008 at 08:06
Robnicko posted:
Phil,
I have, as I said, always used it and never had a problem. I dont like the idea of changing to the HPR15 as it's semi synthetic as a friend whos an engine builder reccomended against changing after so long.
It's happy with the HPR30 so I'll leave it that way. 290000K and no problems yet (touch wood--hand goes to head)
Rob
FollowUp 2 of 3
FollowupID: 608682   Submitted: Tuesday, Dec 23, 2008 at 08:53
No worries Rob, but Penrite recommend HPR10 for your LandCruiser.
If you use a thick oil on a motor that was released 16 years ago, you're unlikely to get "problems", apart from poorer fuel consumption and increased wear on the top of the motor. I wouldn't touch thick stuff on a modern motor.
Mt Finke
LandCruiser HDJ79
FollowUp 3 of 3
AnswerID: 340852   Submitted: Monday, Dec 22, 2008 at 08:13
Member - Olcoolone (S.A) The O replied:
If you can not find out what oil to use by yourself I think you should take your Rav 4 to a QUALIFIED person to get the work done.
There is a bit more to servicing a vehicle then just changing to oil and filter.
Have you thought about phoning Penrite and asking them instead of waiting a couple of days for a reply that may be incorrect.....
A Day At The Beach
I just got lost in thought............. It was unfamiliar territory
Reply 4 of 5
Activities Index
Fly Fishing Half Day for 2 Fly Fishing Half Day for 2
Snowy Mountains / Jindabyne - NSW
Fly Fishing is a great way to fish and there is nothing more relaxing than standing in a stream cast
Two Car Rally Blast - VIC Two Car Rally Blast - VIC
Melbourne - VIC
Are you ready for a real rush?
Surfing Classes in Coffs Harbour Surfing Classes in Coffs Harbour
Coffs / Mid North - NSW
Surfing is one of the most incredible sports and lifestyles you can enjoy.
Mountain Bike Half Day Tour - Rocky Ponds Mountain Bike Half Day Tour - Rocky Ponds
Central Coast - NSW
Experience the Brisbane Water National Park in all it's glory with a mountain bike adventure.
Book Now - Things To Do
AnswerID: 340862   Submitted: Monday, Dec 22, 2008 at 09:50
Robin Miller replied:
Your reffering to the 2.4lt I believe Campervan.
Its the same basic engine as our runout 2006 Rav4 and we use 5-40 Shell helix Ultra which is a full synthetic oil.
Any of the good 5-30w are also ok.
Survivor -Top Crossing Hut Trk
Robin Miller
Reply 5 of 5
