AnswerID: 344591 Submitted: Friday, Jan 16, 2009 at 12:04
HGMonaro
replied:
There's some mis-information in this thread. Being a Pentax DSLR user I'd like to correct some of it.
All Pentax DSLRs have image stabilisation built in to the body. Nikon and Canon have IS lenses. Until recently, that meant buying their 'pro' lenses but both now have consumer kits lens with IS on them. With body based IS, any lens you put on will have IS, even the old manual focus stuff. Generally, both Nikon and Canon cameras will focus quicker than Pentaxes, but Pentax does a 'double check' so will more likely get it accurate. None of them a infaliable.
Pentax cameras have APS-C format sensors, so 1.5x crop factor.
The K200D is not being replaced by the KM (K2000 in some parts of the world). The K200D may be replaced by a "K300D" later/next year. It has the
weather seals and sensor from the K10D but includes 'scene' modes which the K10D (or K20D, it's replacement) doesn't have. Note that without a weatherproof DA* lens the camera is not fully weatherproof.
Any lens (Pentax, Sigma, Tokina, Kirron, Tamron, many others) with P/K on the mount will fit a Pentax DSLR (*istD, K100D, K100D Super, K10D, K200D, K20D & KM). Some Ricoh lenses have an extra lug that can lock the lens on the camera, so if you don't know what to look for, don't put a Ricoh lens on a Pentax. With an adaptor you can use M42 screw mount lenses that date back 40 years (Pentax Takumars and many others). Note that any manual focus lens from the past will still be manual focus, they don't start AFing all of a sudden. Depends on the lens features what camera metering method will be available.
Taking pictures on Green Mode, P mode or any other mode results in a picture with the same amount of information as any other mode. How it represents the scene (exposure) you pointed the camera at may be different.
The majority of my pictures are taken on P mode. I use the exposure compensation button when I need to and the hyper-manual wheels (you can change aperture or shutter speed at any time and it changes the other for you to suit). Occasionaly I'll go to another mode. You can see some examples (not dial up friendly... each page is about 1MB) at
my gallery
Cheers, Nige
Reply 18 of 20
FollowupID: 612557 Submitted:
Friday, Jan 16, 2009 at 14:31
Member - Stephen L (Clare SA) posted:
Hi Nige
Re the point about the K200 D not being replaced by the K-M
When I spoke to the people in
Adelaide this morning, I asked this very question and was told that when their stock on the K200 D and the K20 has been sold, they will not be bringing any further stock into
Australia and the new K-M will be their new Digital SLR Camera, even the K20 will not be replaced at this stage.
The new K-M does not have as many features as the K200 D, yet will be a lot dearer because of the Australian Dollar factor.
I am only repeating what I have been told from the Importers.
FollowUp 1 of 10
FollowupID: 612563 Submitted:
Friday, Jan 16, 2009 at 14:39
HGMonaro posted:
Stephen,
Ok, that's a local view (which we have to deal with if it's the importer rather than an individual
shop) as opposed to a "Pentax" model line-up, which I'm pretty sure will still have the current models until replacements materialise.
Bit of a worry if they run out of K20D's and don't bring in any more... one way to get rid of your user base!
Cheers, Nige
FollowUp 2 of 10
FollowupID: 612564 Submitted:
Friday, Jan 16, 2009 at 14:53
Hi Nige
I agree 100% in what you say. CR Kennedy are the Australian Importers of the Pentax line up and I said that they must be mad, they could not even understand themselves why
Sydney was going that way. There must be logic somewhere being their decision, perhaps to hasten the introduction of their newer 3000 series quicker.
FollowUp 3 of 10
FollowupID: 612650 Submitted:
Friday, Jan 16, 2009 at 21:44
wigger posted:
Hg Monaro (or anyone else who doesn't mind responding)
I have been looking for a DSLR and a Pentax 200D was on my shortlist but didn't go ahead becaus it doesn't have liveview. I realize that
bright sunlight can affect the image but I suspected that a viewfinder wouldn't have sufficient diatropic adjustment because my right eye is bad following a retinal occllusion. What is the experience of bods who have LV. Do you regard it as being like buying a Hilux with no turbocharger?
Is the Pentax 19-55 lens you talk about still a kit lens as oposed to the Sigma?
I've done a lot of homework looking at sites such as DPreview etc
but the mass of
technical detail leaves you feeling a bit overawed.
(Eos 1000D, E 520, Nikon D60VR.............
I am principally interested in photgraphing buildings.
Any thoughts
FollowUp 4 of 10
FollowupID: 612673 Submitted:
Friday, Jan 16, 2009 at 23:37
HGMonaro posted:
Hi wigger,
I don't know what the K200D has for diopter adjustment, my K10D has some built in but I don't know the specs. Just checked the book and it says -2.5 to +1.5 (it uses some weird measurement m to the power -1, whatever that means!). It goes on to say there's an Diopter adaptor that has -5 to +3 available. No idea if the K200D is the same or if that adaptor fits (most likely does). I imagine most camera systems would have similar
accessories, I remember my 35mm Nikon did. It's something you really need to have a look through to see if it's ok or not as you might find you can't see the edges of the viewfinder if the adaptor makes your eye further away from the viewfinder..
If you were to use live view for all your compositioning, I think you can get LCD protectors that have shades built in to block the sunlight. My sister has a E-520 but I've never used liveview with it, didn't know it did that! If you put your camera on a tripod (buildings don't run away on you!) then using live view would be feasable, you only have to see the image good enough to compose and focus. Use the histogram to confirm exposure and don't fuss too much what the colours look like on the LCD (which you need to train yourself to do anyway). I use a 4x5" View camera and it's focusing screen is sorta like live view... just need to put 'ya head under a darkcloth to see anything!!!
Pentax cameras are regularly sold as "kits" with Sigma lenses or Pentax lenses. Just need to make sure you're getting what you want when buying. As I said above, the Pentax DA18-55 gets very good reviews. I've got a 16-45mm so can't give 1st hand experience. If you had a look at my link about, all pics where either taken on the 16-45 or a Pentax DA50-200mm (which is the one that's usually in the kits).
Cheers, Nige
P.S. Stephen, may they know more than they are letting on! hope so!!!
FollowUp 5 of 10
FollowupID: 612711 Submitted:
Saturday, Jan 17, 2009 at 12:06
Member - Heather G (NSW) posted:
Nige,
I just had a look at your gallery and thoroughly enjoyed the experience - I will be more than happy if I can produce similar shots with the SLR.
It has been probably close to 10 years since I used my SLR and I look forward to learning all about the digital one.
Thanks so much for your input.
Heather G
| When you have worn out your shoes, the strength of the shoe leather has passed into the fibre of your body. ~Ralph Waldo Emerson
FollowUp 6 of 10
FollowupID: 612743 Submitted:
Saturday, Jan 17, 2009 at 15:39
wigger posted:
Tks Nige,
Good info. As I said to Stephen (above) it's a good recommendation when you guys say that the DA(why not AF designation?) 18-55 lens is a good one and sounds like you could live with it rather than having to go out and replace the usual kit lens with something better.
I think that I can manage without liveviewand this will be the tradeoff for doing better lenswise. The in body stabilistion has been criticised as being less effective than the lens stab. that
Canon etc use. Is this Valid?
Does the 10D have the same
battery setup i.e.AA's that you would probably need to replace with lithium ion.
FollowUp 7 of 10
FollowupID: 612756 Submitted:
Saturday, Jan 17, 2009 at 17:11
HGMonaro posted:
the DA is the Pentax line of lenses that are only suitable for APS-C sensors (I think there are a few exceptions but generally true). Only a worry if you think you'll buy Pentax's "full frame" digital if they ever release one (the DA lense may not cover the sensor without vignetting) DA* are Pentax's "pro" lenses, which happen to be weatherproof. I think for the Pro Nikon and Canon lenses it's generally accepted that in lens stabiliation is better than in body, no idea about the new consumer ones. Most reports give Pentax a 2 - 3 stops (shutter speeds or aperture changes) for their IS. I uploaded an example of what can be achieved. Not sure this is due to the skill of the operator (that's me... lol!) or the camera :) see
example (a handheld shot @ 1/3sec)
The K10D uses a special
battery (lithium ion) and can't use AA's like the K200D. I have a spare (eBayed from Hong Kong for about $15 inc postage) and the 2 combined I can take a lot of pics. Not sure how many, but probably over 1000.
Cheers, Nige
FollowUp 8 of 10
FollowupID: 612782 Submitted:
Saturday, Jan 17, 2009 at 19:05
wigger posted:
Thanks Stephen,
I thought would buy from you guys but now you tell me that you're R V, it's not poss because as you say a lot of the stores don't stock DSLR's. Latest local R V catalogue only has compact digitals in it. With your knowledge aren't you a bit wasted not working in a specialist camera store but then again I don't know Clare.
Thanks for your guidance. It's been very helpful. I'll go ahead with the 200D because of yours and Nige's recommendations.
FollowUp 9 of 10
FollowupID: 612788 Submitted:
Saturday, Jan 17, 2009 at 19:35
Wigger
You will be more than very impressed with the K200 D You may have problems tracking them down, and the usual selling price is $749, even though their selling price should be a lot dearer. We still have one left in stock with the Pentax 18-55 lens. If you are still having problems tracking one down, get in contact with me. I have sold one to Heather, and she should be receiving it in the next couple of days by post from Clare in SA to NSW
I am a jack of all trades in the
shop that I work. Clare is a small country town in the Mid North of
South Australia.
FollowUp 10 of 10
