I have two 40 Litre Engel fridges in the back of my 79 Series, so probably a similar set up to what you are planning.
The new 40 Litre Engel is rated at 2.5 Amps. I have checked it with a clamp metre and it is spot on. Assuming 50% compressor run time, that gives exactly 60 AH per day. In my experience, the BIGGEST impact on compressor run time and power consumption is ambient temp. But these figures are reasonable for planning purposes.
You don't say if you use your batteries for anything else (lights, charging phone, camera, etc). My thought is that for the fridges alone, 100AH is a bit low. If you use the batteries for anything else, I would certainly add a bit more storage capacity.
In my vehicle, I have a 90 AH AGM in engine bay and a 120 AH in the back with the fridges, so a total of 210 AH. Perhaps more than necessary in most circumstances, but I transferred the batteries from my previous vehicle. Also, I always have one of the fridges (sometimes both) set on freeze.
For charging, I use a 100 W Bifold panel (purchased from Derek Bester at ABR, an advertiser on this site). This works
well, but does not supply quite enough power to replace what I use. I reckon I fall behind at the rate of about 20 to 25 AH per day. This is not a big problem for me, but could be easily solved by adding another panel. I currently solve the problem by:
- minor 'admin' driving of the vehicle every couple of days
- connecting the vehicle to the van, where there are 3 x 130 W panels charging the van batteries.
-occasional running of the generator at a time we might want to use it for other purposes like running washing machine in van (yes I know, over the top, but the van is soon to be our home for a few years).
Long story, so to summarise. One battery and one panel is adequate (just) if
camping for just a day or two, but I reckon you need a bit more battery storage. With an extra battery, one panel will keep you going for 2 to 3 days, depending on conditions. If you want longer time without running vehicle or generator, another panel will need to be added.
All just my view, based on my experience. Hope it helps.
Norm C
346845
Saturday, Jan 31, 2009 at 13:18
Norm, can I ask if you have had to replace/upgrade much of the componetry since it was ramped up for you?
614930
Saturday, Jan 31, 2009 at 13:23
Sorry, but I'm not sure which components you are talking about. Do you mean the
suspension upgrade?
Norm C
614935
Saturday, Jan 31, 2009 at 13:31
OMG, I forgoten allll about that one...I8)
614938
