AnswerID: 352364 Submitted: Thursday, Mar 05, 2009 at 17:29
RobAck
replied:
You put a
snorkel on any vehicle, regardless of engine type for exactly the same reason, to improve the flow of clean air into the engine and to raise the wading depth if you are playing in water.
If you do play in water then one thing that is regularly forgotten and leads to failure of most axle seals is that you should also put diff breather extensions on as well. If you are not aware a diff breather is a small flapper valve that generally sits almost on top of the diff pumpkin, front and rear. The open to allow pressure equalisation when the oil heats up in normal driving. Some vehicles like Troopies have them extended but not very far, normally to the chassis rail only and 120 Prado has the front one extended into the engine bay (correct place) but not the rear one.
If you consider that a hub height water crossing will therefore make water flow over the axles and therefore into the diff breather it seems to make a lot of sense to make this a mandatory part of fitting a
snorkel, again only if you think you will be doing water crossings. You can get kits to fit yourself or do a deal and get it all done when they fit your
snorkel
RobA
Reply 3 of 4
