12 volt high pressure water pump ???
Submitted: Monday, Aug 18, 2003 at 17:04
ThreadID: 6663 Views:6514 Replies:9 FollowUps:0
Is there such thing as a 12 volt high pressure water pump ?
The only 12v pumps i know are the builge pumps for boats but they work on volume and not pressure.
Any ideas ???
Reply By: Rojac - Monday, Aug 18, 2003 at 17:28
Farming suppliers, pumps such as shurflo from 5.3L/min @ max 400kPa - 13.6L/min @max 300kPa, costs $257 & $503 respectively.
Rob
AnswerID: 28316
Reply By: Member - Nigel (QLD) - Monday, Aug 18, 2003 at 17:28
depends on your definition of high :)
try the shurflow pumps from whitworths on hartley st
I use one for a shower pump - has a pressure switch too.
AnswerID: 28317
Reply By: paul - Monday, Aug 18, 2003 at 17:31
as above, what do you mean by high pressure ? supercheap sell air compressor activated water blasters. If that's too high go to any irrigation specialist shop, there's actually quite a lot out there.
AnswerID: 28318
Reply By: Kev - (Cairns,QLD) - Monday, Aug 18, 2003 at 17:50
I dont need real high pressure just enough to hose down built up mud ect.
I will check out those stores tomorow as mentioned, thanks.
AnswerID: 28321
Reply By: Hardy - Monday, Aug 18, 2003 at 18:46
Boat shops sell these.
AnswerID: 28335
Reply By: Eric - Monday, Aug 18, 2003 at 21:11
KEv.
I use a 12volt weed sprayer, avialable from most farm supplies, Eric.
AnswerID: 28363
Reply By: donc - Monday, Aug 18, 2003 at 22:08
Kev, you could also try caravan and motorhome accessory places. they sell shur flo and flojet pumps or variuos pressures. it all depends on how higher pressure your requiring for your needs
AnswerID: 28373
Reply By: andy - Tuesday, Aug 19, 2003 at 15:04
Go To http://www.camec.com.au/product.htm They have everything
AnswerID: 28438
Reply By: Simon - Tuesday, Aug 19, 2003 at 18:53
Kev,
You could also try a pressure vessel such as an air tank or similar filled with water and pressureised.
Even a pump up water/air fire extinguisher would do the trick.
Ive seen an old beer keg used as well.
Drink the beer first!
AnswerID: 28463
