tyre pressures
Submitted: Tuesday, Aug 19, 2003 at 16:57
jaksun
Hi can anyone please tell me the best tyre pressures for a 100series diesel.I have Cooper Discoverer A\T 265/75/16 fitted.
Regards Jaksun
Reply By: diamond (bendigo) - Tuesday, Aug 19, 2003 at 18:06
gday jaksun.
we usually run34-36psi(cold) when we fit them to customers cars.
but different cars have different weights so usually get them to comoe back after 5000ks to see if they need a little more or a little less then every 10000ks after that.—~‘¬‘¥•s’B
28457
Reply By: howesy - Tuesday, Aug 19, 2003 at 20:56
There can never be a definitive answer to this question as your pressures should be constantly changed to accomodate load, surface etc. If your not making adjustments for these factors then budget for tyre replacements on your next trip over some gibber.
28478
Reply By: The Moose - Wednesday, Aug 20, 2003 at 13:49
For bitumen running take the pressure cold, then take it again after a fair run. If the increase is 4psi you had the correct starting pressure. If they've gone up more you started off too low. If they've gone up less than 4 you started off too high. Keep adjusting until you get it right. But that's just for on road. If heading bush don't use that system. It's a totally different game off the tar and as stated above there is no simple answer. The load and road surface will dictate what pressures to run.
28531
