Site Search
Section Image
Fibreglass Long range fuel tank
Submitted: Saturday, Mar 21, 2009 at 08:33
Member - John B (NSW)
Article Overview - Long Range Fuel Tanks
A large number of outback treks involve long distances between fuel outlets. Jerry cans are dangerous, difficult to store and not as convenient as a long range fuel tank. View Full Article...
In preparation for our 12 months trip in July I am considering fitting 185 litre long range tank in the Ute back of our Crew cab 4WD. I believe that there could be a problem with the new ethanol diesel and fibreglass tanks. I believe fibreglass tanks have been used in the marine situation for many years and they are now having a problem with ethanol eating away at the fibreglass tanks. Can anyone advise me on this before I go ahead and fit tank.
Advertisement
ThreadID: 67035 Replies: 3
Views: 1006 FollowUps: 4
AnswerID: 355284   Submitted: Saturday, Mar 21, 2009 at 08:40
Shaker replied:
I think you will find that this will be more of a problem in the marine industry, as ethanol will seperate from fossil fuels when left for periods in excess of 2 weeks, this will in fact eat in to fibreglass tanks.
The other problem is that engines may start on pure ethanol which has lead to manufacturers expessly excludng any warranty claims that may relate to this issue.
I have also just discovered that our local fuel outlet, Tyers Store VIC, only has B20 diesel, with only a tiny warning label on the pump.
I think it should be clearly posted on the roiadside price board that it is B20 to save people, like myself, that refuse to use it from pulling in to maybe find out when it's too late.
Reply 1 of 3
FollowupID: 623309   Submitted: Saturday, Mar 21, 2009 at 09:08
Ozhumvee posted:
Shaker you will find that nearly all diesel in Oz is now partly Bio, can be up to 5% without requiring labelling. The oil companies use Bio to replace lubricity lost when sulphur was removed, otherwise you IP would self destruct very quickly.
John, have a look at this mob http://www.bta4wd.com/category24_1.htm they have shaped tanks to fit in the ute tub at the front and also water tanks in the same config.
Madigan Line 07
Click Image to Enlarge
1988 M1026 Humvee
FollowUp 1 of 2
FollowupID: 623311   Submitted: Saturday, Mar 21, 2009 at 09:11
Ozhumvee posted:
Here is another place that has poly tanks
http://www.dolium.com.au/view?command=cman_view_webpage&action=view&webpage_id=111&pkey=dolium
Madigan Line 07
1988 M1026 Humvee
FollowUp 2 of 2
AnswerID: 355300   Submitted: Saturday, Mar 21, 2009 at 10:31
handy replied:
go wih the poly tanks, you wont go wrong there. cheers
Reply 2 of 3
FollowupID: 623356   Submitted: Saturday, Mar 21, 2009 at 13:46
Peter_n_Margaret posted:
A little practice and a hot air welder, and you can make your own HDPE ('poly') tanks to ANY shape you want, or have someone make them for you.
Cheer,
OKA196 Motorhome
FollowUp 1 of 2
FollowupID: 623398   Submitted: Saturday, Mar 21, 2009 at 19:06
Member - shane (SA) posted:
Peter, can you give more details on this poly welding?
shane.
davenport creek
each to their own.
FollowUp 2 of 2
AnswerID: 355400   Submitted: Saturday, Mar 21, 2009 at 23:15
Motherhen replied:
John, after much searching for something suitable, we purchased a Boab brand poly tank from nearest Opposite Lock shop. Ozhumvee has given you the link. Their poly tanks are only around 50 - 60 litres. We did find an 80 litre in a different brand somewhere - i think from Qld. There are several choices of shape and volume. Currently setting it up secured in the tray, to be plumbed into the fuel line as a back up fuel tank. This is more for security should we hole the main tank, than for extra supplies.
Boab also make stainless steel tray tanks in larger sizes, but the s/s was a lot more expensive.
Mataranka
Well on our way on the homeward run
Reply 3 of 3
