UHF aerial
Submitted: Thursday, Aug 21, 2003 at 19:55
BW
I have picked up a new aerial for muy UHF, and note that it has 27 Mhz on the packet. Can I use this aerial effectively? Thanks
Reply By: Mark - Thursday, Aug 21, 2003 at 21:55
BW,
27Mhz is for AM CBs only, UHF CBs use 476 /477Mhz. In short, no it will not work effectively & could damage your radio !
Mark.
28657
Reply By: Mick - Thursday, Aug 21, 2003 at 23:00
Yes I agree with the first reply. The two radios are completely different frequecies. 27meg is in the HF range and the other is
miles away in the UHF range. 27meg radio waves are 11 metres in size and the most common aerials are one quarter of that either as a straight piece if stainless steel a bit over 2 metres long or the same length in copper wound around a fibreglass stick. The equivalent aerial for UHF is much much shorter. Back to the seller tomorrow I suggest!
28671
Follow Up By: BW - Friday, Aug 22, 2003 at 08:58
Thank you both for your feedback, I am going to change it this morning
BW
19947
Follow Up By: Member - Nigel (QLD) - Friday, Aug 22, 2003 at 20:20
UHF CB waves are around 70cm long - much shorter than the 11000cm of 27 MHz CB - and yes using a not tuned antenna will most likely fry your radio...
20029
Reply By: Member - Nigel (QLD) - Friday, Aug 22, 2003 at 20:21
that should be 1100 cm for 27 Mhz (or 11000 mm) - oh
well - it's friday :)
28778
