Is "heavy duty" Suspension woth the $
Submitted: Sunday, Aug 24, 2003 at 16:53
Brett
Is heavy duty
suspension woth the expense?
Take the 75 series troopcarrier. Leaf springs fitted even after 200,000 km or more
the springs should still be quite stiff, I imagine? Would the fitting of "heavy duty"
suspension actually cause problems in other areas of the vehicle.
Corrugations would shake the car to hell if the
suspension were too hard unless a considerable load were carried all of the time.
Wheel travel. Would heavy duty susp reduce wheel travel?
eg. with more force required to push the wheel up on one side of the vehicle , it would appear that unless the vehicle is loaded to point where
the springs are actually working that it would be easy to have a wheel in the air when more often than if softer
suspension is fitted.
What do you think??
Reply By: Steve from Drive Systems Victoria - Sunday, Aug 24, 2003 at 17:28
You are spot on the money Brett!
Suspension travel, ride quality and longevity of shackle bushes and sway bar bushes are all effected by stiff springing. But, if you need to carry the weight, then you need to carry the weight. Always a compromise.
28921
Reply By: Old Jack - Sunday, Aug 24, 2003 at 18:36
on a Troopy or 75 series ute after 200,000 klm the shackles, bushes and springs will all be stuffed anyway.Most vehcials will be also! if you own another brand don't pick on the troopys wit htime all springs sag! even coils.
They (75 series)tend to suffer SAS as
the springs naturally sag, in fact off road they tend to handle the ruff stuff better asthe
suspension wears to a point due to the spring action becomeing more subtle. as others will no doubt point out
suspension is always a comprimise. with a little common sense most of the time you will find something to suit what ever you are doing.
With leaf springs always keep you shackle bushes & bolts plus shocks in first rate condition.
The biggest thing to remember is that you trucks
suspension is not there as a Fashion statment!
Having to hard a
suspension also causes an increase in breaking distance(tyre skips along the surface of the road rather than follow the surface) also results in
driver fatigue (needing a kidney belt while travelling is no fun!) coil springs in general give a better ride with equal load carrying capacity. that said though there are now some excellant leaf(parabolic leaves) springs available that give a comfortable ride with good load carrying capabiltiy if selected correctly.
28930
Reply By: chopper - Sunday, Aug 24, 2003 at 20:46
I put HD
suspension on my 75 about 180000kms ago, they have not sagged, but ride quality and wheel travel leave something to be desired.
i have just recently had a leaf removed from each corner, has made a big difference to ride, can't yet atest to travel.
28958
Reply By: Prado Boy - Monday, Aug 25, 2003 at 15:30
Anything to do with
suspension is always a compromise - if we could have the all walking/talking/dancing/singing
suspension then the manufacturers would just fit that straight up.
You need to decide what it is you need the vehicle to do most (carry heavy loads, highway driving, bush bashing etc.) then make a decision about
suspension based on that. Once that's done you need to realise that it will strengthen handling under those conditions - but probably weaken handling in others, and drive accordingly in those weakened areas...
Prado Boy
29042
Reply By: Brett - Monday, Aug 25, 2003 at 18:00
Thanks for the response guys. I agree with all of the above.
HD
suspension has always been a "bee in my bonnet". I have on several occasions been to ARB, TJM, etc and spoken to other suppliers at trade shows etc and I have always been directed to Heavy duty stuff with 20 to 50 % the load carying capacity over standard susp. Having driven heavy vehicles for many years I know that the more weight you carry the softer the ride is going to be. Having said that how much weight do we really carry round in our 4x4's when we go on weekend
camping trips or away for a week or 2. From my ecperience it is very easy to over estimate the weight we are carrying.
The
suspension on my troopy has sagged. 330k and 60k over 2 years of that loaded up and towing a camper etc etc through the top end and Kimberly. I would like to return the car to its original ride height and maybe even gain an inch or two but not to the detriment of ride- especially on corrugated roads. I towed 2 other vehicles out of
creek crossings on my last holiday. One was a 100 series which was stuck in the Penticost River in 800mm of
water. He was lightly loaded and could not keep the
wheels on the groung due to poor susp travel. This fellow could not believe it as I drove around him with camper in tow. No LSD either.
Any suggestions on suppliers. I am sure that OME and Ultimate are good but just too many dollars, surely there is a reasonablely priced product out there that can give me a little lift without going heavy duty.
29069
Follow Up By: colin - Friday, Sep 19, 2003 at 15:40
Speak to the guys at offroad australia 4x4 suspensions in victoria 9357 8415. good advice and fair price .
22450
