Drain plug seal on Long Ranger fuel tank
Submitted: Friday, Aug 29, 2003 at 22:31
donc
Help anyone,
what is the seal used on the drain plug / bolt on the long
ranger fuel tanks. The one on my '97 GQ has sprung a leak due to spliting and although only minor currently don't want to be running around for too long with it dripping fuel. It looks like a red neoprene or something similar from the edge of it i can see but want to confirm before i buy a new one.
Many thanks
Don
Reply By: Martyn (WA) - Friday, Aug 29, 2003 at 22:40
Donc,
I would use either copper or aluminium, I suspect that the seal could
well be PTFE, this won't last as long as the two materials I've mentioned and they might be a tad more expensive 5 cents instead of 2 cents, I would always use either copper or aluminium, copper first, good to anneal the copper as
well if you know how. I always carry some spares in the tool bag as
well, you never know when you may have to drain the
tank in the bush, you stand a much better chance of re using copper or ally. My opinion of course.Keep the shiny side up
29609
Follow Up By: Bob Y. - Qld - Saturday, Aug 30, 2003 at 11:01
Donc,
I'll endorse Martyn's comments, and go for copper. Another worthwhile product is Loctite "567" Thread Sealant, as
well as the copper washer. A smear of 567 will stop leaks, even up to hydraulic pump pressures. Far better than bloody thread tape!
Hooroo...
20748
Reply By: donc - Saturday, Aug 30, 2003 at 22:13
Thank you both Martyn and Bob, as soon as i drain the
tank low enough i'll pull the plug and fit a copper washer and hopefull it'll never leak again.
29671
