AnswerID: 367768 Submitted: Sunday, May 31, 2009 at 15:05
Member -Dodger
replied:
For leveling you can get a round spirit bubble from most van
places and just place it in the bottom of the fridge to see if all is level .
As for a owners manual the ones supplied are next to useless and I do not know where you would get one.
Operation is simple ,
Turn it on when on 240v and set the thermostat switch at say 3 then see what the interior cabinet is at after 24hrs with the door fully closed then adjust switch up or down as required. This then should work for both Gas and 240v but not 12v as it is not connected to the thermostat as a rule.
Be aware that on 12v the fridge will use anything up to 12amp hr so it is advisable to run on 12v only when power can be sourced from a car that has the engine running. Usually these fridge's run better on gas than anything else.
| I used to have a handle on life, but it broke.
Cheers Dodg.
Reply 1 of 2
