Fuel Bung.
Submitted: Sunday, Aug 31, 2003 at 14:18
Member - Roger
Hi All,
Do any of you know a way to put a fuel bung in a GU main
tank without taking the
tank out? ( Deisel
tank)
Regards Dodg
Reply By: Steve from Drive Systems Victoria - Sunday, Aug 31, 2003 at 18:04
Well, you can drive a hole into the
tank with a tapered spike and then screw in a self taper with felt washer under the head. It's no good drilling a hole as this removes metal (sometimes into the
tank) so using a punch to form sides to the hole gives the self taper some more meat to bite into.
29719
Reply By: Mick - Tuesday, Sep 02, 2003 at 16:03
I used to work at West end diesel.
We always took the tanks out to do this. We welded a boss in the
tank and use a bolt with copper washer.
Do it once , & do it properly!
29904
