Wednesday, Jun 03, 2009 at 17:36
The
Kennedy Development Road is Dirt from the Lynd to Hugheden. The road between Mt Garnett and the Lynd and the
Croydon turnoff is bitumen, has been widened and is in great condition.
You must be prepared for a gravel road that may not be in the best condition, but as gravel roads go it is OK. Depends how close you get to the last grade. It should have had a grade by now, but there were quite a few washed out
places after this wet. Do a
check on this site and it will tell you if it is currently open.
It has quite a few creek crossings and road trains do use it, they do not travel at the speeds stated above. Pull over when you see them coming and get right off the road is always the best bet.
There is Porcupine George to look at at the Hugheden end. A good drive and have fun. Cheers Tony
635831
