Air Jacks -3 tonne vs 4tone
Submitted: Wednesday, Jan 30, 2002 at 01:00
adrian
Recently bought a Bushranger airjack at Melb. 4WD show - I was told the smaller 3 tonne model (vs 4t) would still do the job on a 98 Pajero but trying it on the weekend it struggled to lift the
wheels off the ground - positioned in the centre under the side step it looked as though there was insufficient height to raise the
wheels. Does anyone know if I was given a bum steer with the 3 tonne model or is there a couple of basics I may have not followed??
Reply By: Jim - Wednesday, Jan 30, 2002 at 01:00
Adrian: you got
well and truly Ned Kelly' d !!!
How does it feel ????
Jim
1884
Follow Up By: Adrian - Tuesday, Feb 05, 2002 at 01:00
Does not feel good - for the sake of $50, the height of the 4 tonne would make a huge diff - thanks for your compassion!
680
Reply By: Ian - Saturday, Feb 02, 2002 at 01:00
Adrian i was dissapointed in the lack of replys to your question i have been thinking of buying one of these jacks and was looking forward to the responses,,i hope u can find the answer somewhere ,,,,ian
1925
Reply By: rich - Sunday, Feb 03, 2002 at 01:00
adrian,
air jacks lift a weight, not a height. If your vehicle is under 3 tonnes (loaded), your jack is ok. Use spare wheel (unless needed for changing!), bits of flat wood or pile a large stable mound of dirt under the bag. Remember in most situataions your vehicle will be up to 18" lower than normal when you actually need to use the jack.
Try avoiding these situations....
good luck have fun - Go the Sube
1935
Reply By: pen - Tuesday, Feb 05, 2002 at 01:00
Have a 3tonne Bushranger and lifts the rear
wheels of my '84 Rangie completely off the (level)ground, did you try upping the idle speed, agree with rich's reply.
1964
thanks to you and Rich. I'll try with increased idle speed and let you know - did you find the location of the bag was critical to lifting the
wheels off the ground ?
679
Follow Up By: Pen - Wednesday, Feb 06, 2002 at 01:00
I wanted to test lifting capability, so in my driveway I placed a 1m x 1m reinforced rubber mat between the jack & rear step/towbar area. I had to run engine at approx. 2k rpm & lifted rear
wheels just clear of ground. My Rangie is equipped with sill tanks, which makes it ideal for placing the jack for side lifts. I have found the jack is far easier to use & more stable than a highlift when on uneven/soft ground conditions. The 4tonne was not available when I bought my jack some years ago, but am very happy with the 3tonne.
686
