AnswerID: 371001 Submitted: Saturday, Jun 20, 2009 at 07:45
Maîneÿ . . .
replied:
can you question the dealer about the precise weight of the battery ?
Compare the weight to the genuine AC Delco Deep Cycle battery.
Yes, as you say "anything that can be used as a cranking battery will lose life quickly after numerous discharges and top ups" when used as DC battery because the plates in a Cranking battery are thinner than those used in a DC battery.
You can get the battery that is claimed to be a compromise and said to be a 'dual purpose battery' but you will find it does neither job perfectly, as it charges slower than a Cranking battery and does not have the extended life of a true DC battery.
Similar to suggesting a Massey Ferguson tractor can be used as a FI race car, they are each designed to do their job perfectly, but not really capable of doing each others job.
Just because many guys use Cranking batteries to run a
fridge, does not suggest they are as efficient as DC batteries when running a
fridge, it only shows it's possible to use Cranking batteries to run a
fridge for a period of time while they are being constantly recharged, unlike a Deep Cycle battery that will run a
fridge for a much longer period of time with-out being constantly recharged.
Maîneÿ . . .
 Click Image to Enlarge |
* check-out how SÔLAR PÔWER & ¹² Vølt Batteries will work *
click-> "My Profile"
below
Reply 4 of 6
