FollowupID: 639972 Submitted:
Thursday, Jul 02, 2009 at 06:54
RV Powerstream P/L posted:
Hi Frank
Yes you sure can connect that way.
The Sterling ProSplitR zero Volt Drop is the most advanced Splitter and controller in the world today and the safest.
Your alternator power goes to it and it then controls seperate lines for cranking battery and auxilliary battery and monitors all aspects of safe charging and eliminates potential backfeed, over voltage and is simple to install.
Connect alt cable connect cranker cable connect aux cable connet ignition feed to properly marked posts.
If youonly need 1 aux then a 2 output would do the job but if you also have a camper you need a three output unit and it will control all three independently .
I will make a special deal for Ecplore oz custromers with Splitter cables and fittings and if you would like to know more please email info@powerstream.com.au
Ian
