Saturday, Jul 18, 2009 at 01:18
Might not.......one install some kinda inflatable air bags with an on board compressor, to raise or lower the lift spec at will.
Drive around the city street among mr plod at normal
suspension body height and ehn offroad and needing clearance you hit the butons on the dash to inflate and lift?
I seem to recall having that feature on a Ford Fairlane back in the mid 80's!
I had the back jacked way up for looks and massive over steer when I attracted the attention of plod who did a U turn and followed me - and pulled me over!
By the time we stopped - the car was normal height.
Guy scratched his head, said he thought I was sporting a illegal jacked up rear
suspension, but on inspection it appeared to be normal.
Told him it was just the lines of the car - from certain angles it created a bit of an "optical delusion" ;o)
He said - I guess so and left, without any warning or tickets!
Later I just inflated it again - the gauge and raise lower buttons were on a small bracket below the dash - the compressor in the boot.
Was great when carrying heavy stuff in the boot for eliminating a saggy bum, & conversely when out with the hoon mates for looking the part with the jacked rear!
I could even adjust the spotlights level on the run bye the air adjustable
suspension....
Lots of good points - and all by air bag shock absorbers & compressor.
Some guys just had the air bag adjustable shocks - plumbed to a tyre valve sstem on the rear bumper and raised them at the servo, with the tyre fill connector (i.e. no on board air compressor).
On the fly adjustment was a bit of a luxury back then.
Can't see why it won't work for 4wd's - lets face it your not gonna get stopped if it looks normal, and when you need that extra lift you hit a button - what could be simpler than that!
375011
Follow Up By: fisho64 - Saturday, Jul 18, 2009 at 02:30
isnt this what the 100 series Lexus has (or Sahara?), when vehicle gets to 60 kmh it drops to normal height.
642286
Follow Up By: OzTroopy - Saturday, Jul 18, 2009 at 14:19
The adjustable
suspension is covered in the rules.
> " 2. The
suspension height must only be capable of being altered when the vehicle is stationary " <
As this aspect is not " height " specific but " adjustability " specific ...It even makes an unregistered 1985 mazda 626 illegal to register now ..... pffffft
This also makes ADR approved, factory fitted electronic, computer controlled override
suspension illegal in NSW vehicles ..... bewdy ..... only got ABS to go now ... LOL
BTW ... citroen and others have been providing adj susp & headlights since probably before this "roads" minister was born ... One would think a "roads" minister would have the aptitude and knowledge for the job ... but apparently not.
642332
