Rear Slide Windows
Submitted: Tuesday, Sep 09, 2003 at 17:44
ogray
Hi All,
I would like to remove the rear slide windows on the HJ60. Specifically to clean the runners and replace some of the rubber surrounds. Does anybody have any info on how these can be removed. Once I get them out I won't have any trouble getting them back in. I guess!!
Also can I buy the rubber surrounds from Clarke rubber or other similar outlets.
Owen.
Reply By: mcgra - Tuesday, Sep 09, 2003 at 18:01
hi owen
do you have a fax number if i have the hj60 toyota factory manual which has all the info.
i'll fax the pages to you tomorrow if you like.
gra
30598
Follow Up By: mcgra - Tuesday, Sep 09, 2003 at 18:03
sorry not sure about the rubber
gra
21639
Follow Up By: ogray - Tuesday, Sep 09, 2003 at 22:02
Hi Gra,
You can send the fax on 43401337. This is
my home number which means I am most likely to answer the phone when the fax comes through. I hope your setup can do a couple of retry's of the fax you're sending to get around this. I will let you know if I have any trouble with it.
Thanks for the response Gra it is appreciated.
Owen
21669
Follow Up By: mcgra - Tuesday, Sep 09, 2003 at 22:37
owen
what state are u in i tried to phone u to arrange a time to fax but i dont know what state yr in.
please post the prefix
gra
21672
Follow Up By: ogray - Tuesday, Sep 09, 2003 at 22:44
Hi Gra,
I am in NSW, area code 02. I have just disconnected from the net. You can call now if you like.
Owen
21675
Reply By: Member - Eric- Tuesday, Sep 09, 2003 at 20:00
once the window is out , I use a thin rop wrapped arount the rubber channel . once you sit the corner in that the rope ends meet , press against the window and pull the rope gently . this will feed the rubber over the panel Craigs hut 2003
30610
Reply By: mcgra - Wednesday, Sep 10, 2003 at 23:24
owen
hope the fax helps out
if u send me an email i will give you a couple of tips on to check out on the hj60.
as i have been going over
mine every weekend just to see the state of lay with it.
and have found a couple of obsure things that i would never of guessed at.
the email addrees i had on page one of the fax was all in lower case.
cheers for now
gra
30737
