GQ Steering Wheel
Submitted: Tuesday, Sep 09, 2003 at 22:17
Zapper
Gday all
I have a 1991 GQ and would like to take off the existing steering wheel and replace it with the later year GQ steering wheel which is quite a bit thicker. Can anyone tell me if it as simple as removing one and putting the other one on? Are the centres etc the same?
Reply By: Truckster (Vic) - Tuesday, Sep 09, 2003 at 22:33
Should be, the boss kit for my sporty type wheel was the same for all GQ's Mr Autobarn told me...
Its a 10 min job to find out!
30631
Reply By: Luke - Tuesday, Sep 09, 2003 at 23:22
yep - just try the swap :-)
super easy....
I fitted an aftermarket wheel to my '90 GQ last week. Stock wheel was falling apart. As far as I could tell the GQ bosses are all the same, so should be fine :-)
30637
Reply By: Martyn (WA) - Wednesday, Sep 10, 2003 at 21:01
Zapper,
It's a good idea to make up a small puller rather than beat the crap out of the steering wheel with a hammer trying to the the old one off, it's on a taper and it can be tight. Plus it shakes the rest of the steering column components to bits.
30720
Follow Up By: Luke - Wednesday, Sep 10, 2003 at 23:17
Mine came of very easily just with a gentle pull once
the nut was off - but you're right - they can be tough and it's not a good idea to beat anything up with a hammer :-)
K-Mart sells a steering wheel puller kit very cheaply :-)
21745
