65w <span class="highlight">solar</span> panel - jaycar & bp <span class="highlight">solar</span>
Submitted: Wednesday, Aug 12, 2009 at 15:43
Member - RMB3218(VIC)
I would be interested to hear any opinions, good or bad, on the jaycar 65w
solar panel (
http://www.jaycar.com.au/productView.asp?ID=ZM9096) They are currently on special for $970 for 2. Also any of the same on BP
solar 65w.(
http://www.bp.com/sectiongenericarticle.do?categoryId=9020477&contentId=7038103)
thanks
Kevin
Reply By: Mandrake - Wednesday, Aug 12, 2009 at 16:36
Seems a little high priced for 65W Multi crystalline ?
Rgds
Steve
378665
Reply By: Lex M (Brisbane) - Wednesday, Aug 12, 2009 at 16:55
I've got a 80 watt jaycar. It works as specified. What more can I say.
378672
Reply By: 4wd 4 Life - Wednesday, Aug 12, 2009 at 18:30
If you
check out
Solar steve's website you can get 2 x 80W panels for not much more than 800 bucks.
I have installed some of his 140w panels and was Quietly impressed that the specs on his panels were as per my
test results when tested prior to installation.
He supplys a small range yet they are all in dimensions usefull for mobile
solar and very competitively priced.
378694
Reply By: 4wd 4 Life - Wednesday, Aug 12, 2009 at 18:32
If you
check out
He supplys a small range of monocrystalline yet they are all in dimensions usefull for mobile
solar and very competitively priced compared to the polycrystalline one your refering to.
378695
