AnswerID: 383554 Submitted: Thursday, Sep 17, 2009 at 20:29
reversemulletman
replied:
Hi all
First time poster so excuse any mistakes.
I think what your installer is reffering to is when the cable is wound on willy nilly, making what my mother would refer to as a "birds nest". As others have said you need run out the cable and wind it back on under tension before you use it. This is true. Doesn't have to be much, just be on a slight incline. Its best to secure to a fixed/stationary object and winch your vehicle towards it and I'll explain why.
Start with at least five turns of cable already on the drum, then take up the strain. If the cable is attached to the left side of the drum, you'll want it to spool across to the right, the second layer will spool across to the left, then right/left/right and so on until you run out of cable.
To do this aim your vehicle off to the left (or the right, depending on what side it's fastened to the drum) so the cable feeds in at about 15-20 degrees off centre. This will roll the cable on hard up against the previous roll. You know if your doing it properly as your should hear a slight ping sound as the cable seats firming up against itself. If you steer to hard left the cable will just overlap itself. Once the cable spools to fully across the drum, turn the vehicle to the right and it'll spool back the other way. Do this back and forth until it's all the way in. What you should be left with is several layers of nicely seated cable from one side of the drum to the other. This is best done with someone in the drivers seat, and you outside controlling the winch and pointing directions to the driver.
Of course this is never going to happen when your dragging yourself out of a bog hole, and more often than not the cable will wind on any old how, resulting in the "birds nest". This leaves several layers of cable crossing each other at different angles and under tension this can result in pressure and pinch spots on the cable, reducing it's life span and causing potential weak points.
After a week end of off roading, it only takes 15 minutes when you get home to drag out the cable and spool it back on neatly (and once again under tension) and gives a good opportunity to check for damage.
Hope this helps (and makes sense)
Brett
Reply 5 of 8
