'Swing Away' Aussie Cooking Stand
Submitted: Saturday, Sep 19, 2009 at 11:19
xxx
I'd seen one of these a few years ago and had been looking ever since. While wandering at the Todd Mall market last Sunday week I came across the manufacturer's stand. They are made in
Alice Springs.
The unit comprises a stake of 1/2 " reinforcing steel which is hammered into the ground next to your fire.
Wing nuts spin down the threaded shaft and on these rest the cantilever arms to which you affix either a spun steel frying pan, or a steel grill. A second arm supports a billy or
camp oven on a chain. The arms allow you to swing the pan/grill/billy away from the fire. The wing nuts let you adjust the height above the fire. The are hooks on the arms for utensils.
The stake, arms, grill and pan weigh less than 8 kg so I was able to bring it home on the plane. It cost $190.
I reckon personally, combining this with a
Bedourie and a
camp oven, you've got just about the ducks guts in out door cooking.
Reply By: greenextreme - Saturday, Sep 19, 2009 at 11:36
Any chance you could upload a photo or perhaps share the manufacturers name / contact details?
383755
Reply By: ben_gv3 - Saturday, Sep 19, 2009 at 11:56
That's a lotta coin.
Pics would be great.
383758
Reply By: 60series_adventurer - Saturday, Sep 19, 2009 at 13:26
Reply By: Gone Bush (WA) - Saturday, Sep 19, 2009 at 13:42
Maybe here:
http://www.campingwithhillbilly.com/products.htm
383773
Follow Up By: Member - Josh (VIC) - Sunday, Sep 20, 2009 at 10:24
Hey Gone Bush, We have used the hillbilly set for years. They are excellent quality and work a treat. We have A single stake that goes into the ground. 2 fry pans that slip over it, a wok and a
camp oven. We can
cook a roast in the
camp oven using only a few heat beads on top when in a c'van with no fires. They are brilliant and very light.
Josh
651628
Reply By: xxx - Saturday, Sep 19, 2009 at 14:09
I am at work at present but will arrange a photo tomorrow.
383779
Reply By: Muddie - Saturday, Sep 19, 2009 at 20:24
Why not try something different, I have been using Firestix for the last few years , they are a simple system, adjustable heat control, frypan, toaster and billy all on at once, packs up into a 50 mm PVC tube and made from stainless steal rod.
I even suspend my
Bedourie camp oven as a stew pot or wok for a sir fry.
regards David
383846
Follow Up By: Member - Poppy (QLD) - Sunday, Sep 20, 2009 at 20:33
Hi David
Where did you get the handle for your
Bedourie?
Cheers Ray
651711
Follow Up By: Gone Bush (WA) - Sunday, Sep 20, 2009 at 20:36
More importantly,
how can you ruin a good breakfast by putting red capsicum in there????
651712
Follow Up By: Gone Bush (WA) - Sunday, Sep 20, 2009 at 20:37
The toaster is brilliant !!
651713
Follow Up By: Muddie - Sunday, Sep 20, 2009 at 21:33
I made the handle, it has a pair of washers welded on each side and springs outward to stop the
Bedourie pivoting, the toaster is a
Bedourie lid with a large trivet welded in. it packs under the
camp oven taking up very little room.
651721
