AIRCON COMPRESSORS
Submitted: Wednesday, Feb 06, 2002 at 01:00
ThreadID: 724 Views:1801 Replies:4 FollowUps:0
HI I AM WANTING TO FIT AIRCON COMPRESSOR FOR TYRES IN A NISSAN NAVARRA DUAL CAB FOR PUMPING UP MY TYRES CAN I DO THIS WITHOUT A TANK OR DO I NEAD TO RUN AIR INTO TANK THEN THE TYRES
Reply By: rod - Wednesday, Feb 06, 2002 at 01:00
Peter you can do it without a tank. I have a tank as it provides a resivour of air as well as pressure (up to 120psi), which is handy for other uses. I think the tank also assists in reducing the amount of compressor lubricant getting into the tyres (my theory).
AnswerID: 1989
Reply By: Ray - Wednesday, Feb 06, 2002 at 01:00
Hi Peter. There are several compressors on the market. Unless you are going to do alot of work with the compressor the tank, although nice, is not necessary. I use a Truck-air compressor Autobarn @$130 which does a great job as long as you through away the cigarette lighter plug and use a better plug
AnswerID: 1991
Reply By: David - Wednesday, Feb 06, 2002 at 01:00
Hi Peter, you don't have to use a reciever tank if you don't want to, they are handy to have , especially if you need to re-seat a bead on a tubeless tyre, i use a modified aircon compressor and run it into a small reciever tank, if you are after a tank try a refridgeration repair place, usually they have hundreds of them that they can't get rid of, 9 times out of 10 you will get them for free or at least very minimal cost, hope this helps, cheers, David.
AnswerID: 1993
Reply By: peter - Friday, Feb 08, 2002 at 01:00
YE THANKS GUYS I WOULD LIKE A TANK BUT HAVE TO WORK OUT WHERE TO PUT IT AND THANKS DAVID I WILL HAVE TO GIVE THE FRIDGIES A GO NOT THAT I WOULD HAVE THOUGHT THEY WOULD HAVE TANKS BUT I WILL GIVE IT A TRY THANKS AGAIN GUYS.
AnswerID: 2011
