Site Search
You have 2 items in your shopping cart
Section Image
Battery charging assumption - True or False?
Submitted: Monday, Sep 21, 2009 at 14:30
WBS
Article Overview - Battery Power
In this article we explain why you might need an additional power source independent of the starting battery installed into your vehicle and we look in detail at types of batteries, how and where to mount them, the role of isolators and the different View Full Article...
I have a dual battery set up with a Redarc battery isolator.
Am I right in assuming that when I charge my cranking battery, and that when that battery is topped up, the charger then starts on my auxilliary battery?
thanks
WBS
Advertisement
ThreadID: 72430 Replies: 11
Views: 1126 FollowUps: 19
AnswerID: 384051   Submitted: Monday, Sep 21, 2009 at 14:37
Vince NSW replied:
WBS, thats how my one works. I have a volt metre on the aux battery which will give the voltage(What else).n start up it will remain unchanged for about 5-10 seconds and then shows around 14.1v.
After the donk is turned of, it will drop slowley to the actual volatage in the battery.
Vince
VKS-737 Mobile 1776
Reply 1 of 11
AnswerID: 384055   Submitted: Monday, Sep 21, 2009 at 15:23
Member - Troll 81 (QLD) replied:
I am pretty sure once the main battery reach 12.7 volts the solenoid will open up
Click Image to Enlarge
Regards, Troll 81
Reply 2 of 11
AnswerID: 384063   Submitted: Monday, Sep 21, 2009 at 16:19
Member - Oldplodder (QLD) replied:
As above, and as you drive you will see the charge go back to the main battery after a while. System keeps cycling.
John C - aka Oldplodder
In touring mode, the way it should be.
Reply 3 of 11
AnswerID: 384064   Submitted: Monday, Sep 21, 2009 at 16:22
Member - Allan B (QLD) replied:
With the Redarc SB112 (current model), as the alternator charges the cranking battery the voltage progressively rises until at 13.2v the solenoid energises and charging of the secondary battery begins.
The solenoid remains energised even after the engine is stopped until the terminal voltage of the connected batteries falls to 12.7v when it then disconnects the secondary battery from the charging circuit. Until it disconnects, any consumption from the "secondary load circuits" is supplied from both batteries, but it would not be for long until the voltage fell to 12.7v.
Accordingly, priority is given to charging the cranking battery before the secondary battery.
Cheers, Allan
Keep your eyes on the prize, hold on
Reply 4 of 11
FollowupID: 651806   Submitted: Monday, Sep 21, 2009 at 17:02
redeye141 posted:
Allan,
10 out of 10 for the explanation.
I have to agree with every word. Have you ever thought of writing manuals for these products?
You have left for dead some of the answer's from experts on 12V stuff of late.
Redeye
FollowUp 1 of 2
FollowupID: 651813   Submitted: Monday, Sep 21, 2009 at 17:57
Member - Phil G (SA) posted:
Yep, nice concise explanation Allan!
WBS,
In the real life situation, the cranking voltage will hit 13.2V within a minute or two of starting. So from that time onwards, the Redarc allows alternator current to charge BOTH batteries. The amount of current flowing to each battery depends on lots of factors, but all else being equal, the battery with the least charge will take a higher current. The current tapers off as the batteries get charged. If the aux battery was half flat, you might find that 30 amps will flow at the start of charging and within an hour might be down to 10 amps, and it will taper down to almost nothing as it approaches full charge.
Think of the Redarc as nothing more than a switch that allows the regulated voltage from the alternator to be applied to the terminals of one or both batteries.
Mt Finke
LandCruiser HDJ79
FollowUp 2 of 2
Activities Index
Private Surf Lesson Private Surf Lesson
Gold Coast - QLD
Have the ultimate one on one surf lesson with a real surfer.
Hang Gliding Tandem at Byron Bay Hang Gliding Tandem at Byron Bay
Far Nth Coast / Byron - NSW
Experience a 30 minute tandem hang glide over Cape Byron.
Noosa Everglades Discovery Afternoon Cruise Noosa Everglades Discovery Afternoon Cruise
Sunshine Coast - QLD
Enjoy a 4 hour afternoon tea cruise of the Noosa River and Everglades.
Kitesurf Lesson Kitesurf Lesson
Brisbane - QLD
Kite surfing is the latest extreme sport that is providing an adrenalin rush to anyone who loves the
Book Now - Things To Do
AnswerID: 384077   Submitted: Monday, Sep 21, 2009 at 17:28
WBS replied:
Thank you all for taking the time to answer my assumption. Appreciated!
WBS
Reply 5 of 11
AnswerID: 384085   Submitted: Monday, Sep 21, 2009 at 18:02
Maîneÿ . . . replied:
WBS
with a mechanical solenoid charging system the Cranking battery is initially charged to a preset Voltage, then the solenoid closes, connecting and instantly equalising the Voltage of the two batteries as just one large battery bank.
If the Auxiliary battery is very discharged and the total Voltage of the battery bank is below the mechanical solenoids preset disconnect Voltage the mechanical solenoid will open again and will automatically disconnect the Aux battery from the charging circuit.
It will continue to recharge the Cranking battery till it gets back up to the solenoid preset reconnect level again.
This connecting and disconnecting of the mechanical solenoid will continue till the Voltage in the Cranking battery and also the Auxilliary battery have equalised at the solenoids preset reconnection Voltage, only then will the two batteries remain in the charging circuit and be charged together as just one large battery.
This is the 'chatter' noise that can be heard in some mechanical solenoids.
Example:
12.6v Cranking battery
10.6v Auxilliary 100ah DC battery
Combined Voltage is N0T (numerical number) 11.6v
but would be ~11v or possibly less in many cases
Yes, different battery combinations will give vastly different Combined Voltage readings
Maîneÿ . . .
wake behind the Stacer 420 SeaHorse
* check-out how SÔLAR PÔWER & ¹² Vølt Batteries will work *
click-> "My Profile"
below
Reply 6 of 11
FollowupID: 651882   Submitted: Tuesday, Sep 22, 2009 at 07:56
Member - Mike DID posted:
"12.6v Cranking battery - 10.6v Auxilliary 100ah DC battery - Combined Voltage is N0T (numerical number) 11.6v but would be ~11v or possibly less in many cases "
Maybe we need a new thread here on the "two batteries connected together will equalise their charge" myth.
If you connect a 100% charged battery to a 0% charged battery they WILL NOT equalise in charge. You need more than 13 volts to charge a battery - a fully charged battery only puts out 12.8 volts.
Here are the results of an ACTUAL WORST CASE TEST.
I connected a fully charged new AGM 80 Ahr battery to a good fully discharged (to 10 volts) wet-cell starting battery. The MAXIMUM current that flowed for a few SECONDS was 32 amps, but reduced to 7 amps after 1 minute.
The total charge transferred from AGM to Wetcell was only 10.7 ampHours after being connected for 2 HOURS, this will not affect the AGM's starting ability !
Keep in mind this was a worst-case test for charge transfer - a fully charged AGM has an open-circuit voltage of 13.0 volts but a wetcell only has a 12.6 volt open-circuit voltage, so less charge transfer would have occurred. You would get LEAST charge transfer if you had a charged wetcell connected to a discharged AGM.
The voltage on the two connected batteries ended up at 12.7 volts because the charged battery still had 90% capacity. The discharged battery would have charged to less than 10%.
The voltage did NOT drop below 12 volts - if this happens you have a faulty battery.
Mike R
FollowUp 1 of 5
FollowupID: 651895   Submitted: Tuesday, Sep 22, 2009 at 09:37
Maîneÿ . . . posted:
Mike
you say: "If you connect a 100% charged battery to a 0% charged battery they WILL NOT equalise in charge"
What do you call the "process" where the Voltage in 2 batteries (not connected to a charging device) are connected together, if it's not "equalise" ??
Maîneÿ . . .
below
FollowUp 2 of 5
FollowupID: 651898   Submitted: Tuesday, Sep 22, 2009 at 09:48
"What do you call the "process" where the Voltage in 2 batteries (not connected to a charging device) are connected together, if it's not "equalise" ??"
When you connect ANY two devices together with a low enough resistance, the voltage will be equal.
The voltage will not be the average, if you connect two different batteries together. A fully charged battery has a much lower internal resistance than a discharged battery, which is why its voltage will dominate.
I wrote that the batteries will not equalise in CHARGE. Too many people blindly apply the Voltage-vs-Charge tables - the tables ONLY apply when no current has been flowing in or out of the battery for a long time - they are meaningless when you have two batteries connected together.
Two batteries connected together at the same voltage do not have the same percentage CHARGE - otherwise a battery isolator would instantly charge the Auxiliary.
Mike R
FollowUp 3 of 5
FollowupID: 651900   Submitted: Tuesday, Sep 22, 2009 at 10:12
Mike,
thank you,
yes I believe "equalise" and "equal" have the same meaning in the context used :-)
Maîneÿ . . .
below
FollowUp 4 of 5
FollowupID: 651903   Submitted: Tuesday, Sep 22, 2009 at 10:38
Yes, different battery combinations will give vastly different "
It's this part of your post that's wrong "would be ~11v or possibly less in many cases " - My real-world tests confirm what theory predicts - that it will be very close to the voltage of the fully charged battery - 12.6 volts.
Mike R
FollowUp 5 of 5
AnswerID: 384087   Submitted: Monday, Sep 21, 2009 at 18:09
Gazal Champion replied:
Hi All,
Well done gents, well done.
This is how a forum should be. design to enlighten and educate, not berate.
Nice to be in civilised company. Sorry, I can't spell!
Bruce.
Reply 7 of 11
AnswerID: 384117   Submitted: Monday, Sep 21, 2009 at 21:36
RodH, Sydney replied:
This is a great thread. Can I ask a follow-on question?
How does the above explanation change when you have a trailer with batteries connected to the vehicle via an Anderson Plug?
Ivy Tank abandonded roadhouse Old Eyre Hwy SA
RodH, Sydney
Reply 8 of 11
FollowupID: 651855   Submitted: Monday, Sep 21, 2009 at 22:24
Member - Allan B (QLD) posted:
The explanation does not change. It matters not where the secondary battery is located, in the engine bay or in a trailer connected via an Anderson plug, the behaviour of the Redarc isolator is the same.
The only additional considerations of having the secondary battery remote in a trailer is that the cabling from the charging source to the battery is of sufficient capacity to allow effective charging without excessive voltage-drop. If the cable capacity is inadequate then the secondary battery will still charge but the current is limited and hence the charge will take longer to complete.
Cheers, Allan
FollowUp 1 of 3
FollowupID: 651891   Submitted: Tuesday, Sep 22, 2009 at 09:26
If you have a really big battery bank (some people have 400 amphours) that's discharged significantly, then you will be reaching the limit of your Alternator to keep up the voltage around 14 volts.
The Auxiliary Batteries may pull the voltage so low that the cause the Battery Isolator to disconnect the Auxiliary Batteries.
Keep in mind that for normal battery installations, current into each battery is determined by the battery - the Alternator attempts to keep the voltage around 14 volts, up until it reaches its maximum current capability.
Mike R
FollowUp 2 of 3
FollowupID: 651917   Submitted: Tuesday, Sep 22, 2009 at 12:38
Interesting proposition Mike, and I follow your logic. But have you actually experienced this behaviour in real-life?
I would have thought that a typical 4WD 100 amp alternator would be capable of maintaing the charge voltage above 12.65 volts (the Redarc drop-out value) even when charging a large bank (400Ah) of significantly discharge batteries.
But then, I have not had the opportunity to observe such situation and may well be wrong.
Cheers, Allan
FollowUp 3 of 3
AnswerID: 384127   Submitted: Monday, Sep 21, 2009 at 22:12
Brian (Montrose, Vic.) replied:
From whats been written my guess would be the trailer batteries would be treated as the 2nd battery by the isolator and would charge accordingly. Does that sound about right?
Reply 9 of 11
AnswerID: 384152   Submitted: Tuesday, Sep 22, 2009 at 07:35
Member - Mike DID replied:
"Exotic claims of Battery Isolator Manufacturers" should be the theme of another thread here in the near future.
MOST Battery Isolators are just a switch that connects the Auxiliary Battery to the Alterntor+Main Battery whenever the voltage is high enough to charge a battery.
Unless you've heavily discharged your Main Battery or unless your Alternator is seriously under-rated, your Auxiliary Battery will start to charge as soon as you start the engine.
MOST Battery Isolators have NO ability to sense the State of Charge of any battery. MOST Alternators have NO ability to sense State of Charge of any battery.
Your main battery may be drawing 30 amps from the Alternator, but the Alternator should still be able to put out 14 volts, causing the Battery Isolator to close and charge the Auxiliary Battery also.
Because MOST Battery Isolators are just a switch, the Marketers have to make exotic claims to convince you to buy theirs instead of the many competitors - buyer beware.
Mike R
Reply 10 of 11
FollowupID: 651885   Submitted: Tuesday, Sep 22, 2009 at 08:07
RodH, Sydney posted:
Hi Mike. Thanks for this.
What happens if your main battery, auxiliary battery and caravan/trailer battery are all different - when the "smallest" battery is charged does that impact the ability to continue charging the other batteries? Should all batteries in a system be of similar capacity for best performance?
RodH, Sydney
FollowUp 1 of 9
FollowupID: 651888   Submitted: Tuesday, Sep 22, 2009 at 09:01
Ray posted:
All I have in the charging system for the batteries in my caravan is a relay that closes when the ignition is on. No fancy Redarc or Arrid in the circuit but I do have heavy cabling to the aux. batteries. I have been running this system for about four years now and have had no problems with flat batteries.
FollowUp 2 of 9
FollowupID: 651890   Submitted: Tuesday, Sep 22, 2009 at 09:21
. . and an automatic Battery Isolator with all the exotic claims will not put 1% more charge into either battery !!!!
Mike R
FollowUp 3 of 9
FollowupID: 651894   Submitted: Tuesday, Sep 22, 2009 at 09:35
"What happens if your main battery, auxiliary battery and caravan/trailer battery are all different - when the "smallest" battery is charged does that impact the ability to continue charging the other batteries?"
A Lead-Acid battery connected to 14 volts will draw current based on its state-of-charge - that's what makes existing car charging systems work where MOST do not monitor battery current or state-of-charge.
As long as the total current draw is within the capability of the Alternator, the voltage will remain around 14 volts - one battery is not affected by the state-of-charge of another battery on the same line.
Once a battery is fully charged, it draws no more current.
Mike R
FollowUp 4 of 9
FollowupID: 651908   Submitted: Tuesday, Sep 22, 2009 at 11:04
By now, WBS (initial post) may be getting somewhat confused!
Cheers, Allan
FollowUp 5 of 9
FollowupID: 651910   Submitted: Tuesday, Sep 22, 2009 at 11:31
Rod, think of your batteries as per the following analogy:
Two water tanks of differing size piped together at the bottom and a pump feeding into the interconnecting pipe. As the pump feeds water to the tanks the level in each tank rises equally, the smaller tank does not become filled faster than the larger tank. Both tanks become filled (fully charged) at the same time.
I can explain the reason for this but it may complicate the issue. The analogy is not exact but near enough for the purpose. And of course it assumes batteries of the same type, both flooded lead-acid for example. I don't want to open up argument of what happens with batteries of differing types!
Cheers, Allan
FollowUp 6 of 9
FollowupID: 651922   Submitted: Tuesday, Sep 22, 2009 at 13:30
Ray: "All I have in the charging system for the batteries in my caravan is a relay that closes when the ignition is on."
This is fine and simple, however there is some risk of damaging the relay contacts and the wiring through the relay by heavy currents being contributed by the auxiliary battery during the cranking phase. Obviously this has not been a problem yet with you.
There is a crafty way of wiring a relay (not solenoid) to connect the auxiliary battery when the ignition is on but inhibit it during cranking ........... wire one side of the relay coil to the ignition circuit and the other side of the coil to the starter circuit. During cranking both of these circuits are at +12v so the relay has no potential difference across it and does not close. Upon release of the cranking action enough current will flow through the relay coil from the +12v ignition via the relatively low-impedance starting circuit to earth and thus energise the relay to connect the auxiliary battery to charge.
Not exactly conventional relay wiring but it works fine on my son's 4wd.
Incidentally, the reason I said "not solenoid" is because of the lower coil impedance of a solenoid which could partially continually activate the starter circuit. Actually, my son's vehicle uses the relay to then operate a solenoid as a slave.
Cheers, Allan
FollowUp 7 of 9
FollowupID: 651925   Submitted: Tuesday, Sep 22, 2009 at 13:39
Pajeros have two Ignition Circuits.
IGNITION1 stays on during starting for Engine power etc.
IGNITION2 stays off during starting, e.g. for AirCon.
Mike R
FollowUp 8 of 9
FollowupID: 651929   Submitted: Tuesday, Sep 22, 2009 at 14:05
Thanks Mike, I learn something new each day!
Then obviously one would connect to "Ignition 2".
Actually, I guess all vehicles with Aircon option would have both Ign. circuits?
Which could explain why Ray has no problem with starting current damage.
Cheers, Allan
FollowUp 9 of 9
AnswerID: 384156   Submitted: Tuesday, Sep 22, 2009 at 07:54
chisel replied:
I think it is a bit misleading to say one battery charges before the other. As soon as the alternator hits 13.2v both batteries start charging. If the auxiliary is small and/or nearly charged already it could reach "full charge" before the starter, theoretically.
Reply 11 of 11
 Page Sponsors
ExplorOz ExplorOz
Phone: (08) 9403 3737
More info | Website
