Sticking Pop Top Seals
Submitted: Tuesday, Sep 22, 2009 at 15:27
arofs1
I have a 2001 Jayco pop top and am having some trouble with the rubber seals between the pop top and the van top sticking together when it is stored for even a short while.
I have tried a number of possible solutions, but not worthwhile success.
Any suggestions.
Brian DJ
Reply By: Member - Allan B (QLD) - Tuesday, Sep 22, 2009 at 15:43
Try coating one surface with a silicone spray such as CRC 808 Silicone Spray available fro auto accessory stores. Will not harm rubber and does not stay greasy.
384202
Reply By: Rod E B - Tuesday, Sep 22, 2009 at 15:58
I use lanolin spray
You can try bay oil too
384205
Follow Up By: Rod E B - Wednesday, Sep 23, 2009 at 11:46
should say
BABY oil
652069
Reply By: Member - Michael P (QLD) - Tuesday, Sep 22, 2009 at 17:21
Hi Brian,
One other thing the tie downs should NOT be tight. The top should have some movement to allow the van & top to "work" independently. You are probably aware of this but mentioned just in case.
Mike.
384217
