GAS SERVICE
Submitted: Tuesday, Sep 16, 2003 at 10:42
ThreadID: 7260 Views:1790 Replies:6 FollowUps:5
HI ALL HAVING TROUBLE WHEN I RUN MY 4WD ON GAS LATLEY IT MAKES LIKE A BACKFIRE NOISE FROM THE ENGINE AREA IS THERE ANY GOOD GAS PLACES IN MELBOURNE I CAN TAKE IT TO REGARDS ROB
Reply By: diamond(bendigo) - Tuesday, Sep 16, 2003 at 13:37
gday robert.
have you changed where you fill up on gas lately.i certainly know if i get dodgy gas backfires wont climb a hillšqUC3<BuIL
AnswerID: 31225
Reply By: Member - Toonfish - Tuesday, Sep 16, 2003 at 15:41
i have had this happen as well watch out for dodgey gas dudes it took me 4 goes to get it right ie 1 did new line placement (too long ) the other tuned it down a fraction and another said timing module (crap).
And finally after 3 new air filter boxes after they all blew up i just replaced the converter.
went well after that .
2 people were dealer recomended!!!!
good luck1999 NISSAN NAVARA DUALCAB
DIESEL 3.2 & SPRINGY CARLTON TOY
AnswerID: 31235
Reply By: Bonz (Vic) - Tuesday, Sep 16, 2003 at 18:21
The guys here (Terang) are excellent, I could ask if you like for a recommended do-er in town ifn ya wantLaterally Literal
Seriously Serial
AnswerID: 31247
Follow Up By: ROBERT - Wednesday, Sep 17, 2003 at 15:46
THANKS THAT WOULD BE A GREAT HELP
FollowupID: 22277
Follow Up By: Bonz (Vic) - Wednesday, Sep 17, 2003 at 16:51
Which bit of town are you in? So I can get one close to you.Laterally Literal
Seriously Serial
FollowupID: 22282
Reply By: howesy - Tuesday, Sep 16, 2003 at 19:19
Just a suggestion but check the water flow through the converter is good as poor flow in cold conditions will do exactly that, and also on the converter there should be a drain plug. Over time condensation can build up inside around the diaphram and cause improper operation of such. Drain it.(turn the gas tank off for safety first)
It's a good place to start and at least you can svae time for a gas guy if you have already done that.
Good luck i hope it's simple and not a drama.
AnswerID: 31250
Reply By: ROBERT - Wednesday, Sep 17, 2003 at 13:11
thanks guys for all the replys i will take all that information with me
AnswerID: 31318
Follow Up By: GOB member vic - Wednesday, Sep 17, 2003 at 20:48
robert what sort of 4b and year
steve
FollowupID: 22305
Follow Up By: ROBERT - Thursday, Sep 18, 2003 at 08:37
the car is a nissan patrol 1991 gq runs ok on petrol then after 20 min on gas its starts to make a backfire noise from bonnet area and a short loss of power at the same time of backfire thanks rob
FollowupID: 22322
Follow Up By: GOB member vic - Thursday, Sep 18, 2003 at 17:56
rob sorry about the questions is it electronic ignition or points if it is points i may have the answer
we drove from alice springs to pt augusta and on to melb with our 89 dual fuel backfiring about every 40ks but we did cure the problem when we got back to melb for $50imagine a 03 gu 4.2tdin the picture
as i am having trouble sizing the picture
FollowupID: 22361
Reply By: Hatcher - Thursday, Sep 18, 2003 at 12:38
Hi Robert,
I might be a little late with this reply, but I would suspect a mixture that is too lean caused by an air leak somewhere on the intake side of the engine. I had a similar problem with my 4Runner and the backfire blew the gas converter in half! Best bet is to take it to a qualified gas mechanic before it becomes too costly. Drive it on petrol for now.
AnswerID: 31410
