Site Search
You have 2 items in your shopping cart
Section Image
Power Socket on LC to connect to Caravan Anderson plug
Submitted: Saturday, Oct 10, 2009 at 08:20
Con_Qld
Article Overview - Battery Power
In this article we explain why you might need an additional power source independent of the starting battery installed into your vehicle and we look in detail at types of batteries, how and where to mount them, the role of isolators and the different View Full Article...
Just wondering if the power outlet socket at the back of the Landscruiser wagon is able to connect to the Anderson Plug on the Caravan to run the 12v fridge while driving? Any advice will be greatly appreciated....many thanks..
Advertisement
ThreadID: 72906 Replies: 3
Views: 683 FollowUps: 3
AnswerID: 386465   Submitted: Saturday, Oct 10, 2009 at 08:34
Tim - Stratford (VIC) replied:
Con,
Are you meaning the cig lighter power outlet in the rear cargo area? If so - this is too light - most people have trouble using this to run a Waeco in the back.
The best plan is to go straight from the battery (with fuse or circuit breaker) to the rear of the car using a heavy duty cable to minimise voltage drop. I ran the cable in split shielding and then into the chassis rail to the rear with an anderson plug. No problems.
Tim
Caledonia Track - May '06
Click Image to Enlarge
Caledonia River Track - May 2006
Another Blog added 22/12/08.
Reply 1 of 3
FollowupID: 654051   Submitted: Saturday, Oct 10, 2009 at 09:26
Go-N-Grey (WA) posted:
I guess you are talking about a LC100. Where did you enter the chassis rail and exit it? Any difficulties getting through?
I currently run external alongside the chassis rail not happy with this though.
I also run through an ignition switched relay so it only works with the engine on. One of the leads to the wiper motor is ignition switched.
Home & Away
Home and Away
FollowUp 1 of 2
FollowupID: 654055   Submitted: Saturday, Oct 10, 2009 at 09:57
Tim - Stratford (VIC) posted:
G-N-G,
Yep - talking about the 100 Series - I entered the chassis rail just near the bellhousing and exited as far back as possible. It was a bit of a challenge but with some soft fencing wire for a chaser it worked ok - wear goggles though - heaps of debris etc falls in your face :-)
The cable runs from a smart solenoid from my aux battery - after seeing Derek's diagram I think I'll go over to a breaker - much better than fusible links and fuses etc. (and mines linked to the wiper motor too)
Tim
FollowUp 2 of 2
AnswerID: 386466   Submitted: Saturday, Oct 10, 2009 at 08:36
ABR - SIDEWINDER replied:
Hi Con
NO !
Best you run dedicated cables, isolator or relay, breakers and then the plugs.
Derek from ABR
ABR - SIDEWINDERABR - SIDEWINDER
Business Member: My Profile
Reply 2 of 3
FollowupID: 654048   Submitted: Saturday, Oct 10, 2009 at 08:44
ABR - SIDEWINDER posted:
The diagram below shows an option to take power off this dedicated cable for other accessories in the back of the car. If you plan to only run the van fridge you can drop the size of the 50A breaker under the bonnet to 20A.
AnswerID: 386483   Submitted: Saturday, Oct 10, 2009 at 10:54
Member - Graham H (QLD) replied:
I ran a 4 B&S cable from Auxilary battery thru a 60amp resetable fuse along top
of r/h chassis rail Cable tied to existing loom already there.
Used same size earth wire onto chassis bolt
Dont need relays etc that way and it has run fridge over nite OK
As we travel everyday battery gets charged OK
Our new home away from home
Another Kiwi that flew the coop
Reply 3 of 3
 Page Sponsors
ExplorOz ExplorOz
Phone: (08) 9403 3737
More info | Website
