3 way fridges
Submitted: Friday, Oct 16, 2009 at 13:40
mashy
i would like to know how good the 3 way fridges are running on gas? i heard they don't get as cold or freeze on a hot day, any help would be great thanks
Reply By: Roughasguts - Friday, Oct 16, 2009 at 13:45
I hear there better on Gas compared to 12 or 240 volt.
But on a hot day you might be right! as the extra hot air behind the fridge is making it work harder.
387351
Reply By: Member - Troll 81 (QLD) - Friday, Oct 16, 2009 at 14:01
I used to have a chescold 3 way and they definitely work really
well on gas. I used to have to turn the dial right back down otherwise the stuff in the fridge side would freeze as
They are crap on 12v
387354
Reply By: Notso - Friday, Oct 16, 2009 at 14:27
Most efficient on Gas, but high ambient temps will stretch their capacity to cool. You can try adding fans to improve heat removal from around the cooling fins.
Works fine on 240 volt but same applies re the high temps.
12 Volt is really only good for trying to maintain temps while travelling. Aside from that they also draw too much current for use unless you have the vehicles motor running during use.
387356
Reply By: Tenpounder (SA) - Friday, Oct 16, 2009 at 14:32
Hi there. I cann't speak about the Chescold free-standing chest type 3 way, but I can talk about the inbuilt Electrolux/Dometic 3 way caravan fridges. First, they are worst on 12v, and best on gas. But there are two levels of these fridges, ordinary and tropical, and many of the fridges around Oz are NOT tropical rated, and simply cannot maintain say 30 degrees below ambient, on whatever energy source you name. So if the inside of our caravan is around 40 degrees, then we cannot hope the fridge to stay much below 10 degrees, even with a shade over the external vents, though we haven't fitted a fan behind the fridge as many have done.
So, in hot weather, we use our Engel for real cooling and especially freezing, and just use the Electrolux to keep salads, butter and vegs sort of cool.
Welcome to Salmonella City!!
387358
Reply By: Member - Heather G (NSW) - Friday, Oct 16, 2009 at 14:35
The newer ones seem to be more efficient than older ones.
I have a 3 way Dometic 184 litre two door fridge/freezer TR around 12 months old now. It works very
well on gas so long as it is level so it is worth getting your vehicle set up level. I keep a fridge thermometer inside
mine and like to keep it below 0 degrees in the fridge compartment.
The dial may have to be turned up a bit more in hot weather but
mine usually stays around 3 or 4.
Heather
387360
Reply By: Member - Matt & Caz H (QLD) - Friday, Oct 16, 2009 at 14:47
Hi Mashy
We have a 3 way dometic, we live in our van (coming up to 12mths now) we run on gas a fair bit and works better that 240V however we are currently in
Kununurra WA most days are 39 - 40 deg and everything (including me!!) struggles in this kind of heat.
Caz
387361
Reply By: The Lobster - Friday, Oct 16, 2009 at 16:21
They work best when they're as level as possible, kept out of the sun with lots of airflow around them, and opened as little as possible, obviously.
I believe they're a better option if you want a
camp site fridge/freezer and you plan on staying in the one spot for at least 3 or 4 days or longer. If you're going to move every 2nd or 3rd day and Engel/Waeco frindge is a better option, IHMO.
Just my $0.02
matt
387377
Reply By: Member - Oldbaz. NSW. - Friday, Oct 16, 2009 at 16:42
I have a 25 year old Finch & it works fine on gas. It does struggle a bit over
40 deg, but will freeze at sub 30 deg if adjusted too high. Also works
well on
240v. 12v is a bit dusty now as element needs replacing. Biggest advantage is
on gas when
camping without power. Nothing wrong with the Engel/Waeco
compressor jobs but you need to spend the cost of the fridge again on either
solar & batteries, or a generator to keep one going for a week in the bush.
To run either type on 12v you must have the correct size wire & plugs as
voltage drop is your enemy.....oldbaz.
387381
Reply By: gjcumming - Friday, Oct 16, 2009 at 17:32
Hello Mashy.
Specifically a inbuilt caravan type or a portable chest type?
Regards: Grant
387385
Reply By: Wilk0 - Friday, Oct 16, 2009 at 18:21
Hi Mashy,
There are 2 types of 3 way fridges Tropical rated and normal. I'd give the normal a miss unless your using it in mild (less then 25-30'c) conditions.
My BIL has a tropical rated fridge and he loves it though it is heavy as on 12v. Far more economical on gas
Ive got an engel and would rather it as my normal travelling is on the move every day or so whilst the BIL tends to go to the river bank and sit for a week.
It a matter of horses for courses.
regards Wilko
387390
Reply By: snapper49 - Friday, Oct 16, 2009 at 21:40
Reply By: 60series_adventurer - Sunday, Oct 18, 2009 at 21:06
We have a Dometic 3 way. (Blue one)We run it on 12v whilst travelling in the car and find it maintains it's cold quite
well, never had anything defrost in the freezer whilst driving. If you do stop MAKE SURE you unplug it cause it doesn't take long to drain the battery, unless you run off dual system.
While
camping we run it on gas. You need to make sure the fridge is level, we use a small spirit level and adjust height so even, it works best when on flat surface.We travelled for 3 weeks and run it on 12v/9L gas bottle and didn't have to refill gas so works quite efficiently on gas.
Hope that helps you alittle.
387633
Reply By: hongkong - Monday, Oct 19, 2009 at 12:58
Mashy I have 2 fridges 1 compreeor and 1 primus gas the gas will go 30-33 below ambient i have tested it and at night it's around -9 and in the day outside is 30 and the primus in -1. The compressor fridge goes down to -19 on full day or night.
Geoff
387722
