Site Search
Section Image
Safety Chains
Submitted: Friday, Oct 23, 2009 at 07:15
Todd66
Article Overview - How to Tow a Trailer
Many people either tow trailers, campers, boats or caravans when they travel. When it comes to towing a trailer or camper on the trip, the traveller will now have much more storage space. View Full Article...
Hi, I've just found this site by accident (as you do when you're surfing) & I have some information that will be valuable to your members. The thread which caught my attention was Forum Post ID: 68159 about a member discovering his caravans safety chains wern't legal.
I manufacture trailers & Safety Chains & Trailer compliance in General is one of my pet peeves. The rules are actually very clear. Every trailer buyer should get a copy of Vehicle Standards Bulletin 1. It's the NATIONAL Code of Practice for building small trailers (<4.5T ATM).
The rule for saftey chains clearly states " All rigid drawbar pig trailers (axle group supporting the majority of the load) must be fitted with safety chains complying with AS 4177.4-4994. This basically means rated chain not mild steel Gal chain as used by 99% of manufacturers. Trailers over 3.5T ATM must use Grade T "lifting" chain. Shackles must also be rated. Up to 3.5T you are allowed to weld the chain to the drawbar. You are NOT permitted to attach the chain to the trailer with shackles. The trailers ATM will determine what size chain & how many are required.
Just as an aside I've seen factory towbars with 2T+ ratings that don't have provision to take a 2T rated shackle!!
VSB 1 also states that "It is the responsibility of the manufacturer to ensure that the trailer when FIRST SUPPLIED TO THE MARKET meets the requirement of the ADR's." You are completly entitled to go back to the manufacturer with VSB 1 in your hot little hand & demand they fit compliant safety chains. VSB 1 also states that you can persue the issue through Trade Practices if they don't comply.
Everyone please do this as the industry need a bit of a shake up. While you're reading VSB 1 you will probably find that 90+% of trailers are illegal in some way. Remember you as the "operator" are liable for the compliance of your vehicle/s once it's driving down the road!!!! Todd Seymour CSE Trailers
Advertisement
ThreadID: 73240 Replies: 4
Views: 985 FollowUps: 10
Post Reply Thread Watch Back To Forum Alert Moderator FAQ
AnswerID: 388329   Submitted: Friday, Oct 23, 2009 at 07:29
Fiona & Paul replied:
Thanks for the information Todd, I'll be checking ours out to make sure they are OK and the last thing I want is to see the van going past us sometime.
The New Sleeping Quarters
Click Image to Enlarge
Paul H
Reply 1 of 4
AnswerID: 388334   Submitted: Friday, Oct 23, 2009 at 08:22
Member - Fred B (NT) replied:
When something goes wrong..... and the law comes down hard on you (the driver), ignorance of the law is no excuse.... Yet it is impossible to keep up with all the laws and regs in one state, let alone the nation. Even most businesses don't know the laws applicable to their own industry.
Thanks for the heads up Todd.
on the road to Nhulunbuy NT
Fred B (NT)
VKS 737: Mobile/Selcall 1334
HFOz: HFOZ/Selcall 1334
Reply 2 of 4
FollowupID: 655969   Submitted: Friday, Oct 23, 2009 at 08:46
Todd66 posted:
This one is reasonably easy because its all in VSB 1. Your right tho because getting the detail can some times be difficult. It's taken me a while to find the detail on AS 4177.4-1994 (had to pay $37 to download a copy of just the safety chain part).
The basics are your safety chain must have 4177 stamped on at least every 4th link. If it doesn't it ain't legal & if it fails YOU will be liable.
Here's a link to VSB 1
http://www.infrastructure.gov.au/roads/vehicle_regulation/bulletin/pdf/vsb_01.pdf
AnswerID: 388349   Submitted: Friday, Oct 23, 2009 at 10:13
Dion replied:
Todd66,
AS 4177 Part 4 covering Safety Chains, I assume your "AS 4177.4-4994", the 4994 is a typo and actually means 1994.
This is not current, the current AS 4177 Part 4 is 2004 which is re-issued April 2006 with ammendment 1.
It's nice providing AS's, but they need to be current or they are no use to man or beast.
Not sure about the price to purchase, I just looked it up, AS 4177.4-2004 (incorporating ammendment no. 1), pressed print and there it appeared.
regards,
Dion.
Reply 3 of 4
FollowupID: 655982   Submitted: Friday, Oct 23, 2009 at 10:24
Sir Kev & Darkie posted:
Dion,
You may find that the current version of the Aust Standard is not called up in the current legislation. Therefore the AS 4177-1994 is the Australian Standard that is deemed to be Legal.
I find this every day with my work as a Building Certifier. The Pool Fencing Australian Standard is not the latest, although there are moves afoot to get the latest AS called up into the respective States Building Legislation.
Cheers Kev
The Pyrenees
I am NOW living in Chinchilla, the Australian Melon Capital ;)
FollowUp 1 of 5
FollowupID: 655998   Submitted: Friday, Oct 23, 2009 at 12:15
Dion posted:
Kev,
acknowleding your comments, however consider that a paper copy of what ever is as only current as the minute it is printed. ie it then becomes uncontrolled.
The only controlled document is that which is available electronically from the sponsor of the document.
Consider that the legislation is lacking and hasn't caught up with the times, although 5 years does seem a tad long.
As for the superseded AS 4177-1994, as it is no longer a supported electronic doc, I would see that in a dispute where the AS is called for, that regardless of what whichever state legislation is being used, it's the current document that will stand up, not the superseded document.
Perhaps point out to the legislation that AS4177 has been superseded and it does not refer to the correct document.
regards,
Dion.
FollowUp 2 of 5
FollowupID: 655999   Submitted: Friday, Oct 23, 2009 at 12:22
But it does refer to the AS 1477 - 1994 which therefore makes that version the Legal document. Being available electronically is irrelevant as there is still means for that document to be access from the Australian Standards Board, and quite possible also contained within the relevant Regulations which are the explanatory documents used to support the Legislative Acts.
No Australian Standard is correct unless it is actually referred to in Legislation. Just because a newer version of the Australian Standard is released does NOT make it a Legal document.
Cheers Kev
The Pyrenees
FollowUp 3 of 5
FollowupID: 656064   Submitted: Friday, Oct 23, 2009 at 19:08
Member - Tonyb (FNQ) posted:
trailers of ATM up to 2.5 tonnes must have at least one safety chain complying
with AS 4177.4 –1994, or as amended from time to time;
The document makes it clear - it calls up the amendments the way I read it
FollowUp 4 of 5
FollowupID: 656068   Submitted: Friday, Oct 23, 2009 at 19:13
Below may help for QLD Trailers - Mild Steel chain is allowable
AIS INFORMATION SHEET No. 12(a)
SAFETY CHAINS FOR TRAILERS UP TO
AND INCLUDING 3.5 TONNES ATM
Trailers up to 2.5 tonnes ATM must have at least one safety chain complying with AS
4177.4 - 1994 (Trailer and light trailer towing components – Safety chains up to 3.5 tonnes
capacity), or as amended from time to time. This standard allows for steel safety chains in
accordance with the following:
• up to 1.0 tonne, a chain size of 6.3 mm;
• up to 1.6 tonnes, a chain size of 8 mm;
• up to 2.5 tonnes, a chain size of 10 mm.
Trailers over 2.5 and up to 3.5 tonnes ATM must have two safety chains complying with AS
4177.4 - 1994 or as amended from time to time. This standard allows for steel safety chains
in accordance with the following:
• up to 3.5 tonnes, a chain size of 13 mm.
The fitting of safety chains to trailers with a Gross Trailer Mass (GTM) greater than 2.0
tonnes and fitted with a brake system that automatically applies if the trailer becomes
detached from the towing vehicle, is optional.
However, trailers of and in excess of 3.5 tonnes ATM, all medium and heavy category pig
trailers with rigid drawbars, any other trailers without breakaway brakes and all fixed and rigid
pig trailers with a GTM greater than 2.5 tonnes and fitted with automatic pin type couplings,
must be fitted with safety chains in accordance with the information contained in AIS
Information Sheet 12(b) – Safety Chain Requirements.
Draw Bar Safety Chain Attachments
The chain must be permanently attached to the trailer, shackles are not permitted.
For trailers up to 3.5 tonnes ATM, the safety chain attachment can be by welding. The weld
must extend around 50% of the circumference of the link and the adjoining link must have
free movement.
For trailers of and in excess of 3.5 tonnes ATM, safety chain attachment must not involve
welding or deformation of the chain. Suitable pin lock couplings should be used.
The safety chain attachment must be located as near as practicable to the coupling and,
where 2 points of attachment are required, they must be mounted one on either side of the
centre-line of the draw bar.
FollowUp 5 of 5
AnswerID: 388386   Submitted: Friday, Oct 23, 2009 at 14:24
Bob replied:
Todd when discussing VSB1 you state "Shackles must also be rated"
Could you please point out where VSB1 calls for rated shackles.
Darned if I can find it.
I am reading version 5, June 2009.
Is there a later version?
Reply 4 of 4
FollowupID: 656074   Submitted: Friday, Oct 23, 2009 at 19:39
Member - Graham H (QLD) posted:
Seems a bit pointless going to the trouble of fiting rated chains and using ratsh*t shackles doesnt it
Our new home away from home
Another Kiwi that flew the coop
FollowUp 1 of 4
FollowupID: 656106   Submitted: Saturday, Oct 24, 2009 at 06:18
Member - Andrew (QLD) posted:
It does Graham, though why would Hayman Reese supply such a setup with their towbars?
$5 (consumer price) for a 1.5t rated shackle is not much money, however HR etc don't go down this track of having them stamped. Must be a reason i guess.
It may be that my sole purpose in life is to
serve as a warning to others!
FollowUp 2 of 4
FollowupID: 656129   Submitted: Saturday, Oct 24, 2009 at 10:59
Didnt get any shackles with my towbar, they came with the van.
They are stamped 2t ones and the chains are stamped as well.
FollowUp 3 of 4
FollowupID: 656154   Submitted: Saturday, Oct 24, 2009 at 15:54
Thanks Graham,
My towbar came with some "blackish" smooth D shackles, with HR stamped on them IIRC.
FollowUp 4 of 4
Activities Index
See Melbourne and Beyond Attraction Pass 2 days See Melbourne and Beyond Attraction Pass 2 da
Melbourne - VIC
Attraction pass for Melbourne & Beyond. Over $1000 worth of admission fees.
Sydney Harbour Luxury Sailing Sydney Harbour Luxury Sailing
Sydney - NSW
No visit to Sydney is complete without sailing it's unique Harbour and it's beautiful 160 kilomete
Luxury Saturday Sailing Cruise - 2 hours Luxury Saturday Sailing Cruise - 2 hours
Mornington / Bellarine - VIC
Sail aboard our catamaran as we explore the Mornington Peninsula to see cheeky seals, playful dolphi
Champions Brock Experience - General Admission Champions Brock Experience - General Admissio
Rockhampton Region - QLD
Be inspired by the history of motorsport legend, Peter Brock.
Book Now - Things To Do
 Page Sponsors
Phone: 1800 21 21 21
ExplorOz ExplorOz
Phone: (08) 9403 3737
More info | Website
