AnswerID: 389905 Submitted: Wednesday, Nov 04, 2009 at 00:29
Maîneÿ . . .
replied:
John,
The numbers used to nominate the capacity of solar panels is the Maximum Watts which in many cases won't even be attainable unless in reasonable conditions.
The numbers you need to know are the reasonably expected Watts in reasonable light conditions, however they are never quoted.
Some cheaper solar panels will not work efficiently in low light, so the number of AH per day is reduced even in good conditions.
Don't expect to get 120 watt performance from a 120 watt panel all the time, it just won't happen.
I did a 'test' with my 200+ watt solar system, with no cleaning and having it laying horizontal in part overcast conditions, it only returned dismal performance numbers on the day, however on a good day it shows >12 Amps @ the gauge, not the extremely dismal (7 to 8 Amp) numbers I've shown below.
With my SÖLAR system laying horizontal on the roof it starts recharging the AGM battery system at dawn, even in these real life conditions, and with the panel NOT cleaned of bird dung & dust etc.
@ 7 am
SÖLAR system is collecting 3.8 Amps
(I know this only because I checked)
Battery is showing 14.2v (charging Voltage)
@ 9 am
SÖLAR system is collecting 7.5 Amps
Charging 2.3 Amps into the AGM's
in previous 2 hours has collected 10ah
@ 11 am
SÖLAR system is collecting 8.5 Amps
Charging 1.2 Amps into the AGM's
in previous 4 hours has collected 13ah
@ 1 pm
SÖLAR system is collecting 8.6 Amps
Charging O.4 Amps into the AGM's
in previous 6 hours has collected 20ah
@ 3 pm
in previous 8 hours has collected 26ah
(can't fib, lost notes with other numbers)
@ 7 pm
SÖLAR system is collecting Zero Amps
Charging Zero Amps into the AGM's
in previous 12 hours has collected only 29ah
During the day there were times when almost nil Amps were showing, hence the extremely low 29ah total for the 12 hours, instead of a realistic 50+ Amphours.
The 25 year warranty on solar panels is not worth the paper it's written on if you don't know the manufacturer of the panel, as it's only based on panel performance, not the panel failing because the wiring has cracked or solder breaks because the panel has vibrated them loose, which is usually given a lesser 12 month quality warranty.
I would only use AGM Deep Cycle batteries.
Maîneÿ . . .
 Click Image to Enlarge |
* check-out how SÔLAR PÔWER & ¹² Vølt Batteries will work *
click-> "My Profile"
below
Reply 3 of 8
