Window Seal Lube
Submitted: Monday, Sep 22, 2003 at 20:45
ThreadID: 7362 Views:1760 Replies:2 FollowUps:5
Can anyone recomend some type of lube that i can use on the rubber seals to make my windows wind easier that wont affect the reubber.Its not the regulator as I checked that when I replaced the glass holder .
Rob
Reply By: Truckster (Vic) - Monday, Sep 22, 2003 at 20:47
Take the rubbers off and clean them, and the glass, its not a quick job, but works. I use Windex on both.
AnswerID: 31706
Follow Up By: Rojac - Monday, Sep 22, 2003 at 20:59
I cleaned the window a few weeks ago when it was apart,the rubbers didnt look too bad just a wipe over and I cant be bothered doing that again not so soon.
Maybe the silicon idea but will it bugger up the rubber...make it go brittle??
Rob
FollowupID: 22622
Reply By: GLAYVA MAN(bendigo) - Monday, Sep 22, 2003 at 20:50
gday rojac.
i used to have problems with my fairlaine power windows.
i used a spray can of silicon lube not cheap but it worked.
ask repco ect for it jamieson wild cat
AnswerID: 31708
Follow Up By: jules - Tuesday, Sep 23, 2003 at 09:54
Silicon spray is ok - but make sure it is DRY silicon - repels dist and dirt - wet one just makes a mess
FollowupID: 22645
Follow Up By: BJ42turbo - Tuesday, Sep 23, 2003 at 19:25
jamieson wild cat ??? what's the story
FollowupID: 22682
jamieson wild cat ??? what's the story..........Dazz
FollowupID: 22683
Follow Up By: GLAYVA MAN(bendigo) - Tuesday, Sep 23, 2003 at 20:10
gday bj42.
its a bit of a joke between al and mrs all and my self jamieson wild cat
FollowupID: 22687
