Thursday, Nov 12, 2009 at 14:19
Hi Woolbroker,
Outbacktourer has provided good advice.
As an owner of a series III Di 3.0 Patrol, I think that the problem with your turbo is unfortunate, it is even more unfortunate that it has taken out your aftercooler and motor.
The turbo is made by Garrett and is a GT2052V, these are very good turbos and your mishap is certainly not common on these motors. The turbos like any other mechanical part needs to be looked after and the best way of doing that is by using good oil and allowing the turbo to cool down prior to shutting off the motor (ideally wait until the temps are 200c after turbo).
The "blow up" problem that a few members on other forums enjoy blowing out of proportion (pardon the pun) can be typically contributed to a faulty MAF sensor.
This is not a "Nissan" thing, it is the same on all high tech diesels that do not have an EGT sensor feeding information back to the ECU.
Prevention is always better than the cure so by installing EGT and boost gauges, we are able to see if ever the electronics are not working correctly and we are able to catch all problems (except real mechanical ones like yours) before it causes damage to the motor.
The challenge is really to advise all who have these high tech motors to install the two gauges - then keep on enjoying the truck...
Another thing that we should all be weary of is the implementation of EGR on these type of motors. EGR is not bad per say but when mixed with blowby oil, the exhaust particles turn into goop and slowly block the intake manifold which is very bad for a diesel.
There is a simple fix for this as
well, install a good quality blowby catch can. If you have had your vehicle for a while, then I would suggest that a clean of the intake manifold would also be required (throttle body and inlet of the intake manifold can be accessed and cleaned without too much difficulty).
The 3ltr motor is a good design and members from another
forum that have striped them down after 260Ks have found the internals to have minimal wear, the problem was a hole in the piston due to a failed MAF sensor:
"Just my thoughts from what I found when I pulled mine down after the problem
at 263,000K
wear in
bore - too small to measure
twist in head - less than 1/2 thou
intake and exhaust manifolds also less than 1/2 thou twist.
big ends - not run in yet. Numbers still readable on shells.
mains - identical with the new ones, thickness, ovality and yaw. no wear there at all.
So with new engine australia pistons, and a weather eye being kept on the maf (with a spare in the glove box) I reckon she's good for at least 1,000,000 K "
As you can see, the motor is good but the electronics are what can let it down - by installing a boost and EGT gauge, it won't get the chance.
Here is a link to a page that shows
Site Link what Ks are possible with this motor.
Whitie
390994
Follow Up By: Woolbroker - Thursday, Nov 12, 2009 at 17:42
Whitie,
Obviously allot of people like their Nissan vehicle's no shame in that at all and most of you know what is needed to stop the problems and also anyone reading these forums do too. It's good stuff..... I even had a chap give me a link to a manual that fixes allot of the problems that's great also..and really it's not until the sh_ _ hits the fan when we all hear the stories or even listen at all.
Look I'm not trying blame anyone for my Nissan blowing up as I have tried to do my best and look after the vehicle as it is a necessity to have a
well maintained vehicle for the line of work I'm in.
Many blogers have made mention to allot of good points and I appreciate all the comments but I can't see pass the fact that Nissan need to give the Nissan owners and prospective purchases all the facts about potential problems or even give them some good service advice. It is very disappointing when so many people tell you that "mate your vehicle should do 300 000 kms + and it doesn't, but maybe they would if everyone is told the facts.
Nissan service advice needed or Nissan problems will keep happening.
Our company can't get out of them quick enough sorry..
658852
Follow Up By: whitiepatrol4x4 - Thursday, Nov 12, 2009 at 18:26
Totally understand and agree with you Woolbroker, unfortunatelly most Nissan service departments (or choose another manufacturer) do not know the benefits of the gauges - some will even scare you away from them saying that it will void the warrante if you install them... I do not think that they will be advocating them any time soon :(
If your problem was caused solely by the turbo, the gauges may or may not have helped but a Garrett turbo blowing in this manner is not something that you hear about often. Usually, there will be some indication that the turbo is going and you will typically hear it unless the problem was caused by oil starvation to the bearings, this may be caused by (amongst other things) not allowing the turbo to cool down before shutting the motor off.
I am just letting you know that this is not purely a Nissan thing, most (jf not all) of the diesels that are high tech at the moment still do not have an EGT sensor feeding back into the ECU and are using a similar turbo - if there is no EGT sensor, then you need to install it yourself. This is the number one mod in the states when you purchase a diesel, it is just not known here I guess?
Most if not all new diesels are also using EGR to help meet the stringent polution laws so IMHO a blowby catch can is also required.
Gone are the days of the purely mechanical diesel motors, the new V8 Toyo has about twice the amount of sensors as does the Nissan 3ltr CRD but I have not seen an EGT sensor on it either.
Whatever you get into, if it is a turbo diesel and has electronics - put an EGT gauge and a blowby catch can on it. You will be
well on the way to be able to enjoy lots of trouble free Ks with that setup.
658855
