help needed for a dual battery set up
Submitted: Tuesday, Nov 17, 2009 at 17:07
baldman
Hi all,
We are getting ready to drop a new motor into my 4 runner and whilst the engine bay is empty we are going to take the opportunity to give the engine bay a once over and tidy up all the wiring that has been added over the years..
We are also going to install a dual battery system at the same time.
What I do need explained to me is the terms" in parallel", and" in series".
As some may know many diesel surfs and 4 runners came factory with a dual battery set up.
These systems were apparently set up to crank the engine off both batteries and from what I understand do not lend themselves very
well to having a battery drained and then recharged via fridges, and
inverters.
What I am looking for is a dual battery set up that cranks off one battery, but allows me to run accessories of the other whilst still being charged. In the scenario of the primary battery going flat I would also like a switch to allow me to start of the second battery.
Does any one make this type of set up.
Baldman
Reply By: ABR - SIDEWINDER - Tuesday, Nov 17, 2009 at 17:49
Please re-type the link.
391523
Follow Up By: ABR - SIDEWINDER - Tuesday, Nov 17, 2009 at 18:12
I see it is a server problem.
659424
Reply By: ABR - SIDEWINDER - Tuesday, Nov 17, 2009 at 20:21
Hi Baldman
Have a read of this news_letter it may help you.
V_S_R
Derek from ABR
391535
Follow Up By: ABR - SIDEWINDER - Tuesday, Nov 17, 2009 at 20:26
This explains parallel and series if you are not sure.
P_vs_S
Derek from ABR
659433
Follow Up By: baldman - Tuesday, Nov 17, 2009 at 22:57
Thanks Derek,
checking out your website.
659457
Reply By: Maîneÿ . . .- Wednesday, Nov 18, 2009 at 09:53
baldman,
You ask: "What I am looking for is a dual battery set up that cranks off *ONE* battery, but allows me to run accessories of the other whilst still being charged.
In the scenario of the primary battery going flat I would also like a switch to allow me to start of the second battery"
Too easy, fit a quality built larger CCA capacity Cranking battery, and replace the second Cranking battery with an AGM Deep Cycle battery and place an *electronic isolator* between them.
Run your 'accessories' like radio, fridge etc (N0T winch) from the AGM DC battery.
You can use the AGM DC to crank if your true Cranker fails at some time in the future by using a mini 'jumper cable' system if you install an isolator that has two bolts that attach the (+) cables
(not a piranha type/style unit, reason being they have the cables going direct into the epoxy body of the unit, check out the Rotronics link for a better idea)
LINK:
Rotronics Electronic Isolator
Image Could Not Be FoundMaîneÿ . . .
391598
Reply By: Mark & Jacqui - Wednesday, Nov 18, 2009 at 22:47
G'day Baldman,
I use a Redarc isolator, it has an override switch so I can pull in the auxiliary battery if the starting battery has a dummy spit. $85 from Ashdowns.
Mark
391684
