In Car Camera
Submitted: Thursday, Nov 19, 2009 at 00:31
ThreadID: 73840 Views:2844 Replies:5 FollowUps:3
We have just designed and built a slide on camper for our 2009 dual cab Hilux. It works really well but we'd like to be able to see/check on our boat trailer whilst driving.
We have considered installing a reversing camera with a manual on off switch. However we wonder what the image would be like at 100 kph
Anyone tried anything similar that's worked or know of a company that could help us?
Reply By: johntoyo - Thursday, Nov 19, 2009 at 03:04
Try a wireless rear view camera. It's activated and gets its power from (any 12v source) the running lights / tail lights which we always drive with on.
My camera is mounted high up on the rear of the van to remove that blind spot. I would not use it to safely reverse into a site (use 2 way for that) but I know when I am being 'tail gated'. Works in my case effectively over about 12m.
Try a search on e-bay for plenty of choice. They are straight forward and simple to install.
Good luck
AnswerID: 391701
Reply By: Wayne (NSW) - Thursday, Nov 19, 2009 at 06:56
Ali L,
A reversing camera can be fitted to the top of the slide on camper to give a view of the boat trailer.
Having a camera on all the time shouldn't be a problem. It can be wired up through a switch and that will mean that it can be used when required and not just when the vehicle is in reverse.
The image will not be affected by speed, however I have a camera mounted on the bull bar of the Troopie. Looking at the monitor with the front camera on and travelling at speed the road does come at a rush. The camera for the back of the Troopie is mounted on the roof rack which gives a good high view behind the vehicle.
Wayne
AnswerID: 391704
Reply By: Ray - Thursday, Nov 19, 2009 at 10:02
I have a camera mounted on the rear of my caravan which is on all the time the c'van is attached to the car. It does have provision for a second camera so you could have one to watch the boat and the other as a rear view.
I bought mine off e-bay from Brash Imports. They have quite a selection of systems. Do not go for a wireless system as they are not very reliable and are subject to sperfy radio signals. It may be a good idea to have a word with Derek at Sidewinder.
AnswerID: 391723
Reply By: Member - Graham H (QLD) - Thursday, Nov 19, 2009 at 10:38
DONT BUY A WIRELESS camera
I have tried them all and the wireless one was useless.
It worked great in line of sight of the receiver but the amount of metal
between the camera and the receiver defeats the signal
If the prev poster got his to work hes lucky as I shifted the receiver to the back of the car and it still didnt work.
It was one of Brash's as well.
Try this seller on EBAY 95soarer
He sells good stuff which is generally cheaper than Brash.
Speed makes no difference if the camera is mounted securely.
AnswerID: 391726
Follow Up By: Alpal1 - Saturday, Nov 21, 2009 at 17:08
Hi Graham, Does 95soarer have a web site, I have looked on ebay , all I see is 3 pages of the same stuff over & over.
FollowupID: 659992
Reply By: Member - sdr00y (Beecroft,NSW) - Friday, Nov 20, 2009 at 22:19
I bought one of these (see ebay item number below) in 2006 and have it wired up so it is on all the time, something I have found unnecessary. I am about to change the power to the camera so I can switch it on and off when I need to. I have it mounted on the inside of the troopie rear door, but you would mount yours outside which should be better than mine. Mine is a colour camera but when the camera looks through the glass of the rear window it loses its colour ability, possibly because of the tinting. Also the infra red reflects back into the lens at night, again something you will not have to deal with if you don't mount it behind glass.
It works a treat. Great vision side to side. Adjustable up and down to suit where you mount it so you can look down close to your tow bar or look out similar to a rear view mirror, past what you are towing to what is further behind.
Great value for the price I feel.
This model uses a video cable which in my opinion is better than wireless. It also has infra red which is great for night viewing/reversing.
Mine is over 3 years old and still working great, even thought I would suggest to extend the life of this camera, not to have it running all the time, just when you need it (reversing or towing).
Ebay item number 350270132512 is a buy it now one, 250533258932 is same model but bid for it, 250533252397 is the similar model just with a better resolution. The lower resolution ones are fine.
I am not connected to the seller in any way. I have dealt with Brash imports and found them to be quality items and easy transactions.
Also, I am viewing it on an LCD screen 16 cm wide and 12 cm high. I am sure that makes a difference too. Don't get a tiny screen, you wont see anything properly!
As for the image at 100 km/h, the boat will be moving at the same speed as the car so it will appear crystal clear in the screen. The trees, lines on the road, guard rail and what ever else is out to the side of the car will be a blur no matter what camera you have. The blurriness has more to do with the refresh rate of the screen compared to the speed of the vehicle more than anything to do with the camera. No matter what camera or screen you get, some of the vision of the stationary items on the road will be blurry at 100 km/h, what ever is travelling at a similar speed to you will be clear (ie the car behind or what you are towing etc).
Don't go out a buy a package deal either. You should be able to find a camera to suit (as suggested above) and a screen to suit your vehicle and all you need to do is mount them, provide them with power and link the two with audio-visual cable with RCA plugs at each end. Cable can be bought at jaycar or dick smith or places like that. Probably a 5 m lead would do.
I have a flip down screen mounted to the overhead console of my troopie and have removed the rear view mirror from the windscreen. I don't use it all the time so it is handy to be able to fold it up out of the way for the majority of the time.
Hope this helps.
sdr00y
SD
AnswerID: 391955
Follow Up By: Ali L - Saturday, Nov 21, 2009 at 15:11
Thanks for providing such a comprehensie reply. We have checked out everyone's suggestions so far and are getting close to a final selection. A users perspective is so much better than just a salesman
FollowupID: 659977
Follow Up By: Member - sdr00y (Beecroft,NSW) - Tuesday, Nov 24, 2009 at 14:21
No Dramas.
SD
FollowupID: 660382
