front or back diff lockers
Submitted: Wednesday, Sep 24, 2003 at 21:54
ThreadID: 7418 Views:2359 Replies:8 FollowUps:13
I am considering getting a diff locker fitted to my turbo diesel rodeo as it has a lsd am i better to install the diff locker to the front instead of the back
REGARDS CHEF
Reply By: Truckster (Vic) - Wednesday, Sep 24, 2003 at 21:59
yes
AnswerID: 31921
Reply By: Member - Peter D M - Thursday, Sep 25, 2003 at 06:31
chef
i have a lock-rite diff lock in the front of my rodeo and the difference is very noticable. i definitly recomend the front.
regards peter petermoyle@mullum.com.au
AnswerID: 31941
Reply By: Tony - Thursday, Sep 25, 2003 at 07:01
For the amount of traction effort you get from the rear about 70% I would put the diff lock in the back. You will use it far more than if you fitted it in the front.
AnswerID: 31942
Follow Up By: Truckster (Vic) - Thursday, Sep 25, 2003 at 15:56
If you have a good LSD in the rear, you would waste it putting in a Locker... WOuldnt be much more advantage over the LSD.
Locker and LSD is the go.
FollowupID: 22818
Follow Up By: Old Jack - Saturday, Sep 27, 2003 at 13:51
The rodeo LSD's are very good and yep, truckster is correct go for the Locker/lsd in the front! if he had a toyota with one of their lsd's with over 50,000k on it I'd say put it in the back first!
FollowupID: 22964
Reply By: Member - Eric- Thursday, Sep 25, 2003 at 07:36
you have a LSD in the rear , which is a form of locking device ( not a good one ) and in the front, you have a open diff . It makes sence to fit it to the front to maximise traction off road . Someone else stated about the rear using 60% , thats only on a constant 4x4 withought diff lock engaged .
fitting to the rear only stops the rear diff from braking traction at around 90 pounds of torque pressure , which is what happens in a LSD
fitting to the front will give possitive traction to both wheels , were you only had possitive traction to one .Craigs hut 2003
AnswerID: 31946
Follow Up By: Tony - Thursday, Sep 25, 2003 at 07:56
That's all very well as long as you keep all wheels on the ground, but driving up steep rutted tracks most of the traction effort goes onto the rear wheels, 70%, a LSD and thats what it is limitted "slipping" diff does not produce the traction to stop the vehicle slipping all over the place, diff lock in the front with one wheel off the ground most of the time due to the IFS front end will place a lot more strain on the CV joints and the traction gained is not the extra 30% needed to drive slow and carefully.
No one spoke about the 60-40% drive of a constant 4WD.
Therefor as a long time user of diff locks IMHO you get better service with a diff lock fitted in the rear. Sure the best is to have two but in this case the question asked which end is better for one.
FollowupID: 22785
Follow Up By: Member - Eric- Thursday, Sep 25, 2003 at 08:23
You can go on about this topic for days , in most cases i rear wheel pushing and two front wheels pulling is a far better way to create forword momentem . There are areas that having a rear lock is better , but we are talking about accross the board
You can go and on about what if this wheel is off the ground and about if this slips this way or that way Craigs hut 2003
FollowupID: 22787
Follow Up By: Tony - Thursday, Sep 25, 2003 at 08:53
If it's across the board we are talking about, you can use the rear diff lock and not have the vehicle in 4WD and with it in the rear you get no slippage, as in the LSD you still get some.
FollowupID: 22788
Follow Up By: Member - Eric- Thursday, Sep 25, 2003 at 18:13
I dont see why you would need a rear lock , if you arn't in 4x4 , if the road is good enough not to use 4x4 , then i dought there would be a need for a diff lock, or do we need to dig up the tacks just to see how far we can go with our cars in 2x4 , just to show whos is longer :-)
Just a debait please dont take any offens , Craigs hut 2003
FollowupID: 22838
Follow Up By: Member - Eric- Thursday, Sep 25, 2003 at 18:16
Forgot to add , what I opted for , was rear lock right , front air lock , I am very happy , the rear does like to growl every now and then Craigs hut 2003
FollowupID: 22839
Reply By: Tony - Thursday, Sep 25, 2003 at 08:29
Isn't that what FWDiving is all about, getting out in the bush and enjoying it, and in doing so look after our vehicles and more importantly the tracks. Having a vehicle set up properly will do both.
AnswerID: 31952
Reply By: Member - Ken - Thursday, Sep 25, 2003 at 09:55
G'day Chef
I have a 1HZ Diesel Troopy which is 3.5 tonnes all up when heading 'out'
I had a rear diff locker fitted first (ARB) and a year later a front ARB locker(when I could afford it)
I use the rear locker heaps and the front locker when perceived difficulties arise or it all turns to bleep .
I agree with Tony's comments and the thing that no one has mentioned so far, is steering with a front locker engaged. Weeeeeeeeeell! lets just say its something else again.
Anyway, why don't you contact the makers of air lockers (ARB) at their HQ'S in Melbourne, not their suburban shops, and ask their technical opinion rather than listen to us amateur experts.
Ken
AnswerID: 31956
Follow Up By: Janset - Thursday, Sep 25, 2003 at 14:29
Hi all.
As stated above.
I have been down that very expensive trial and error path starting with an auto locker to the front and the standard troopie rear LSD.
With the front wheels locked up in loose beach sand or any other types of loose sand,..... I can not think of any other better way of GETTING bogged. Forget about steerage in mud!
I have written a detailed article on this matter some time back, suffice to say.......Pooh to an AUTO front lock!
If you must get a locker in the front. PLEASE make it one that you can engage or disengage your self.
MY end result.... Removed the Detroit Soft-locker from the front and replaced it with an Detroit True Trak LSD and now have ARB in the rear.(A deal done with Detroit)
This setup is just the ducks nut's, only thing better would be ARB in the front and rear.
An auto locker to the rear......don't know, have not had any experience with that.
FollowupID: 22812
Follow Up By: chopper - Thursday, Sep 25, 2003 at 14:55
I've got an auto front locker and, after a brief learning period, have had no problems with steering.
Just come off the power a little and around you go!
FollowupID: 22813
Follow Up By: Janset - Thursday, Sep 25, 2003 at 15:37
Hi Chopper.
Under normal off road conditions I will agree with you.
I do not know where you drive, so I can't comment as to your case, but what I can say is, when in loose sand with an all up weight of 3.2 tonnes , when the foot comes off the pedal the vehicle stops.. PERIOD!
If you turn in loose sand, with both wheels driving, one drives the other acts like a bulldozer blade pushing the sand in front of it until a stall or very close to it occurs. And yes, I do let my tyre's down, and yes I have experimented with different pressures.
When leaving the beach up a sand dune, there is invariably always an sharp left or right turn midway . The front wheels tow like an express train until the turn. Take you foot off and you stall mid turn (no more momentum) , don't take your foot off ....'hello bush'
If you stop in loose sand and then drive off again, instead of the wheels walking out like they do in an open diff, they both dig in and bury you, most of the time.
As I said before, I have been down this path. I put up with the Auto locker in the front diff for 2 years of regular club activities under most conditions before I said quits. So the decision was not taken lightly
As I said, an expensive exercise. Believe me it hurts to admit to your self that you made a wrong choice and then have to fork out again to convert the front diff. Had it not been for Detroit coming to my aid and substituting the Diff, I do not know what I would have done.
As is, it still cost me $250 for the exchange, removal and re-installation of the TrueTrack LSD.
Knowing what I know now, I would have bit the bullet, saved some more money and gone ARB front and rear. What I have now is about 90% traction all up but certainly better than the problems I had with the Auto front Diff locker.
Having said that, if you are happy with what you got, then that is all that counts.
FollowupID: 22817
Follow Up By: chopper - Thursday, Sep 25, 2003 at 17:00
Janset, we are going to have to agree to disagree on this one, A lot of my driving is on Fraser Island and Kinkuna, quite often with trailers.
(and i do a lot).
I love my lokka(s)!!
FollowupID: 22824
Reply By: srowlandson - Thursday, Sep 25, 2003 at 12:00
I'd go rear before front any day.
Front RARELY get used, i.e. 1-4 times a year, where as a rear can help you a lot more (say 20-30 times)
Front Lockers work wonders for blowing a CV ;)
Lockers are well overrated nd well overused in my opinion.
Steve
AnswerID: 31965
Follow Up By: Member -BJ (Sydney) - Thursday, Sep 25, 2003 at 17:03
Hows the Prado Steve?Regards Bob
Where to next
FollowupID: 22825
Follow Up By: srowlandson - Thursday, Sep 25, 2003 at 17:11
The Prado is fantastic.
Why i didn't buy one earlier i don't know.
IFS drives well, very capable offroad, small outide, roomy inside, well built and solid.
Steve
FollowupID: 22827
Reply By: kezza - Thursday, Sep 25, 2003 at 19:49
Chef
Depends on how good your rear LSD is - (some times its just finding the right LS oil)most who have a poor performing rear LSD will rightfully replace it with a good locker 1st. Make sure you check the oil possibilities first because on some makes there are some great LSDs (and some dogs too).
Its amazing how little difference there can be between 2 vehicles with good rear traction and one having a front locker and one just having low tyre pressures,
Youv'e just gotta weigh up what you do most of the time - how much money you want to spend and how dedicated you are to letting tyres down and pumping them up again.
I know a few people who wonder why they bothered with a front locker once they got the rear traction working properly wether it be locker or good LSD.
Ring Penrites Oils tech staff to see what they can do for your Rodeo's LSD first, if thats no good then go rear locker first.
On the other hand if someone owned something like a Patrol I'd get the Penrite limslip 140 into the LSD and put in a front air locker.
Kezza
(Oh and I do know what I'm talking about - Im not guessing or making it up or talking about a mates mates experience)
And there was no hint of sarcasm in my last statement either! (wink wink)
AnswerID: 32019
