uhf cb radio
Submitted: Thursday, Sep 25, 2003 at 09:25
uppy
Hi guys can anyone help me i can get a Phillips UHF,CB,FM93,WI 30 WATTS transmitter radio for around 70.00$ as i dont know a thing about radios. Is this a good price? and is this what i need to travel around Aust.Your advice would be great.
regards uppy
Reply By: Phil G - Thursday, Sep 25, 2003 at 09:58
I think its only 10 channel, and the legal limit is 5 watts.
For more info, go to
http://members.fortunecity.com/romeo_fox_53/
I wouldn't buy it. Spend the extra money and get a Uniden or GME.
31957
Reply By: Bonz (Vic) - Thursday, Sep 25, 2003 at 13:53
I think that they are a commercial radio, we used to have them at work for our private system, forget about it I think, it works on a different UHF freq set
go for the GMELaterally Literal
Seriously Serial
31971
Reply By: floyd - Thursday, Sep 25, 2003 at 16:56
If that radio is 30 watts then it is not a uhf cb. You will not be able to contact anyone other than thse with the same chanels fitted. If it operates outside of the 477 meg range then you will need to purchase a license and get aproval from the Australian Communications Authority. Then you may not hear anyone on it anyway especially in the outback so it will be useless. It is against the current law to operate within the 477 band with over 5 watts too. If it has been modified to include the cb chanels then you will be able to talk to other uhf operators however it sounds like the type of radio that real estate agents and couriers would use. Philips are also known to be a bit "Deaf" when it comes to distant signals.
31996
