Sand Drifts - Corner Country
Submitted: Monday, Dec 21, 2009 at 18:44
Member - Cantiva Clay (NSW)
Hi All, I am thinking of heading into
Corner Country at the end of the week and quite a lot of the road warnings include "care/extreme care - sand drifts" - Can someone please define sand drifts and how much of a problem they are?
Reply By: Notso - Monday, Dec 21, 2009 at 19:05
It's the sand moving across the country driven by wind.
Always take extreme care when going over dunes as the track may
well have blown away on the windward side of the dune, leaving a drop off on that side.
395978
Follow Up By: Notso - Monday, Dec 21, 2009 at 19:07
Sorry forgot, drifts are usually very soft as
well so you can go down to your axles easily
664665
Reply By: DIO - Monday, Dec 21, 2009 at 19:17
Keep an eye on the weather reports. Lots of rain (100+ mm) expected in far north and north east of South Australia as a result of rain bearing depression from TC Laurence. I'm not exactly which
corner country you are referring to.
395980
Follow Up By: Dave B ( BHQ NSW) - Monday, Dec 21, 2009 at 19:20
Do a search on
Corner Country and see what comes up.
664667
Reply By: Peter_n_Margaret - Monday, Dec 21, 2009 at 20:30
The road east towads
Cameron Corner, mid April 2009.
OKA196 Motorhome
395987
Reply By: jdbb - Monday, Dec 21, 2009 at 21:28
We did
Tibooburra to
Cameron corner and back about six weeks ago. We went in on the Middle Rd through Sturt NP and came back on the southern road. The Middle Rd was rougher than the other one. Had no problems with sand or anything else. Was a bit warm and would be worse now.
At
Cameron Corner they said the
Bore Track was the best way to get to Innaminka, next best was the new Strez. We met someone who tried the Old Strez at the same time and they said it was pretty rough. We didn't hear anything about sand being a problem at that time.
regards
395992
Reply By: Willem - Monday, Dec 21, 2009 at 21:30
Basically what you have to do is drive to the conditions. Occasional sand drifts may be on the crest of the dunes but the roads around the
Corner Country and hard packed as showed in the pic above. I wouldn't worry about it.
395994
Reply By: Member - Cantiva Clay (NSW) - Tuesday, Dec 22, 2009 at 00:46
Thanks all for your reply, have to pop down to
geelong and planning on taking the scenic route......a lot more interesting than the hume ...ok and a little bit longer!
396011
Reply By: Member - Russnic [NZ] - Tuesday, Dec 22, 2009 at 07:06
I was in that area mid October
Strzelecki ,
Walkers crossing ,
Birdsville and back round to
Innamincka then down old Strzelecki and onto Camerons Corner, roads not too bad apart from the gibbers and corrugations.
Sand drifts all along the old Strzelecki most of the way just needed a bit of caution, sand drifts occurring on the top of dunes Camerons corner area needed more caution with road being one lane at times on the top of blind crests.
Take care if pulling over on those crests.
I pulled over on a crest to give way to an approaching road train, that I could see coming many dunes away, and also take some photos, then found I had to put the hubs into gear to get back onto the road as it was deceptively soft on the shoulder, pleased I was only going slow when I pulled over.
396017
