Glind shower mounting
Submitted: Wednesday, Oct 01, 2003 at 10:35
Moose
Does anyone have pics of where they've mounted their Glind heat exchanger and pump in a petrol 80 series Cruiser? Thanks in advance.
Reply By: JohnR - Wednesday, Oct 01, 2003 at 18:37
No pics sorry Moose, but just remember there is little vibration with these pupms, they can be mounted vertically for the spindle. Probably best to have the pump below the motor because of potential leakage and keeping the electric motor dry. That being the case keep the motor above planned
water heights for river crossings. Can be on the firewall or any solid surface, including guards near the
water source.
In most cases the pumps are self priming, but be aware that dirt can get under the valve
seat so best if the
water head is high to make it easier to prime the pump. In a wagon or troopie the pump could be adjacent to the
tank inside the panel work I would guess.
The crucial thing about the heat exchanger is keeping the pipework for primary heating
water short and the heat exchanger from vibration or striking damage letting your precious
water go. Not sure if the Glind has taps to turn off
water going to the heat exchanger, but they would help protect your engine coolant loss. A mate has his mounted in the back of his bull bar for protection. Out of the way and easy to put a brass garden connection drilled into the bullbar to easily access the
water at the front of his 4by. Just a clipin for a shower, turning on your taps.
Others may have piccies.
32523
Follow Up By: Moose - Thursday, Oct 02, 2003 at 12:27
Re your vibration comment on the heat exchanger. According to Glind it isn't an issue. Their recommended mounting point is on the motor itself. They provide diagrams and specific instructions for such mounting. They say that of the hundreds (or was it thousands) they've mounted there none have had any problems.
23289
Reply By: Tuco69 - Wednesday, Oct 01, 2003 at 21:49
Hi Moose - it's not an 80 series, but here is a pic of the Glind/Flojet under the bonnet of our Surf.
http://www.users.bigpond.net.au/jose_ozorio/Glind%20install.jpg
Maybe you can get a few ideas that you can use with your 80.
Tuco
32549
Follow Up By: JohnR - Thursday, Oct 02, 2003 at 14:48
Moose, just read again, the vibration potential is the motor not the heat exchangerjust safeguard is required to save against loss of coolant or
water. Vibration in motor but is small and there are rubber feet on all the ones i have seen.
23301
