3.0 Turbo diesel Patrol problems
Submitted: Wednesday, Oct 01, 2003 at 17:21
ThreadID: 7536 Views:10758 Replies:8 FollowUps:4
Hi there people,
Have any of you out there had any experiences with 1999-2001 Patrols blowing engines?
I'm in Canberra and have started hearing problems about Patrols blowing pistons and such. I'm interested as I've had some pump and electronics problems with my 2001 series II Patrol and want to start seeing if there are any trends with failures and such.
If you have a Nissan Patrol 3.0TDi with any major component problems then please post away!
Regards Chris.
Reply By: Member - Bradley- Wednesday, Oct 01, 2003 at 17:25
Mate, do a search in the previous posts for 3.0td problems and all your questions will be answered. But i'm sure you will recieve plenty of good responses anyway (and start a blue or two !!). cheers BradLife is short- but there's always time for a yarda.
AnswerID: 32511
Reply By: Member - Roger - Wednesday, Oct 01, 2003 at 17:28
Shold a got a 4.2Dodg
AnswerID: 32512
Follow Up By: chrisfrd - Wednesday, Oct 01, 2003 at 20:32
Well!
I had a 4.2 GU before. Did about 190,000K's in it. Nice, but bleep it was SLOW! Even after squeezing about 30KW more from it by blueprinting, bigger exhaust and pump recalibration.
The 3.0 that I have now has a bigger exhaust, D-tronic and better filters, is MUCH nicer in power delivery (except for take-offs where the 4.2 kicks it's arse!) but I'm finding that people may be having cylinder-head problems, turbo shagging faults and such.
Currently, The NSW Police at Cooma have two Patrols that have had stuffed engines, my mate has a Patrol with 140,000K's on it with blown cylinders 1 and 2 (and he's religious about his servicing), the work Patrol has had upgrade has a blown turbo. Something is missing with the reliability eh?
FollowupID: 23248
Reply By: Member -BJ (Sydney) - Wednesday, Oct 01, 2003 at 17:30
I have a 2000 3.0 ltr only 2 problems, air flow meter & sub tank fuel pump both fixed under warranty . Do an archive search plenty of posts on 3.0 ltr. if your warranty is not up & you are worried extended warranty costs about $700 for further 50,000k's. Mine has 65,000 k's on it & only the 2 prob's.Regards Bob
Where to next
AnswerID: 32513
Reply By: Spanky - Wednesday, Oct 01, 2003 at 19:18
Another satisfied Nissan customer. Do a search and read the gospel truth on the Patrol.
If you have any specific questions you should send them to Member Bob. He is the NISSAN GOD. He is the king and knows all. My kids worship him and my mother in law reckons he is the bees knees and is the President of 4WD in Australia. Go Member Bob GO.
AnswerID: 32530
Reply By: Andrew - Wednesday, Oct 01, 2003 at 20:57
over a thousand Patrol Owners at:
http://autos.groups.yahoo.com/group/Patrol4WD
there is also a poll being run on that site for 3.0TDi Patrol owners.
AnswerID: 32545
Follow Up By: srowlandson - Wednesday, Oct 01, 2003 at 21:48
I had a 3.0 Gu
July 2000 Build
drove 99270 in it prior to trading in on a New Prado
Problems i had:
Seized Idler Pulley / A/C Compressor (also took out the Fan belt and Fan) Warranty
As above but this time water pump dead, alternator and a few other bits. No Warranty $4500 fix, no parts had to wait 2 weeks
Clutch gone at 55,000 (went Heavy Duty then) No Warranty $1500 fix - 1 week
Cracked Flywheel - replaced Warranty - 1.5 weeks to fix
Just prior to trade, Leaking water pipe (cracked weld) 2 weeks to get part, traded it in before the parts arrived.
My brother is on Gearbox number 3, Engine Number 2, AC and Idler number 3, has also done a few air flow sensors, had his turbo rebuilt etc.
Steve
FollowupID: 23257
Follow Up By: Truckster (Vic) - Thursday, Oct 02, 2003 at 15:57
I WANT A THREE LTR GU OH YES I DO!
FollowupID: 23307
Follow Up By: chrisfrd - Friday, Oct 03, 2003 at 12:13
YIKES!!!
RUN FOR THE HILLS!
My clutch is fine, but the gear box is always SLOW to sync between 2,3 and 4. I never use 5th below 80 cause the engine speed is fine and 5th is a weak point in any design.
The engines seem to be running far to close to distruction for my likeing. I may need to get a V8 conversion if the thing does go south.
We did a clutch for a mates 4.2 a few months ago, $650 was the deal, with a heavy duty Bendex jobby.
FollowupID: 23377
Reply By: Patrol22 (Queanbeyan - Thursday, Oct 02, 2003 at 13:23
Wow...this is all making my head ache (almost as much as the 3.0lt owners' wallets). Makes my 2.8tdi patrol seem like an absolute gem.
AnswerID: 32596
Reply By: Goona - Thursday, Oct 02, 2003 at 20:10
stick with the 4.2 Turbo and you can't go wrong
AnswerID: 32633
Reply By: chrisfrd - Monday, Oct 06, 2003 at 22:39
Naa!
It's time to rip out the 3.0 and replace it with a nice new Cummins TD.
More power and less cost in the rebuild!
AnswerID: 32935
