Elbow grease
Submitted: Saturday, Feb 06, 2010 at 10:48
ThreadID: 75811 Views:4450 Replies:10 FollowUps:7
Hi all,
I have some stains on my stainless steel pots that go inside my shuttle chef. I've tried putting them in the dishwasher several times but it doesn't seem to remove it. I asked my old man and he said use elbow grease and that'll remove it.
There lies my problem, I've search every where for someone to sell elbow grease but no ones seems to stock it, I've googled for suppliers, tried all the major suppliers Castrol Fuch's etc but no one has it.
The Old guy at the local garage said he hasn't seen much elbow grease used around here in years.
Has anyone out there got a tin or tub in there shed that I might be able to purchase?
Thanks in advance for all your help,
Cheers Wilko
Reply By: Ups and Downs - Saturday, Feb 06, 2010 at 11:05
I've got some, but can't find the left handed screwdriver to open the valve to get it out.
If I find that I'll send you some.
Paul
AnswerID: 402943
Follow Up By: Wilko - Saturday, Feb 06, 2010 at 11:27
Thanks Paul,
Let me know how you go lol
Cheers Wilko
FollowupID: 672481
Reply By: Sir Kev & Darkie - Saturday, Feb 06, 2010 at 11:26
Wilko,
You are looking in the wrong spots.
They are located in both Building and Plumbing Outlets right next to the Long Weights and Rainbow paints.
HTH
Cheers Kev
Russell Coight:
AnswerID: 402945
Follow Up By: Wilko - Saturday, Feb 06, 2010 at 11:30
Thanks Sir Kev,
I tried Bunnings for them but the Kid who served me itll have to be ordered in as they didnt stock it lol.
Cheers Wilko
FollowupID: 672482
Follow Up By: Sir Kev & Darkie - Saturday, Feb 06, 2010 at 11:32
Bunnings is NOT a Building or Plumbing outlet, it is a hobby store ;) there lies the problem
Russell Coight:
FollowupID: 672483
Reply By: Member - Fred B (NT) - Saturday, Feb 06, 2010 at 11:37
You will find the elbow grease in the same section as common sense and sky hooks; both are just as difficult to find as the elbow grease.... lol (:
Fred B
VKS 737: Mobile/Selcall 1334
AnswerID: 402946
Follow Up By: Member - Tony V (NSW) - Saturday, Feb 06, 2010 at 12:56
I found it....
Sky hooks are there as well
"Using ancient secrets from the famous sky rope climbers in India, the new KaleCoAuto Skyhook set is perfect for the home mechanic! Comes in a set of four (for each corner of your vehicle.) Simply attach the top of the chain to the sky, and hoist any object up to 700lbs per chain, onto each hook!"
As left handed screwdrivers are only metric,the imperial ones are out of stock.
"This screwdriver was specially formulated by the Coalition of Left Handed Peoples for the Furthering of Left Handed Recognition and Also the Metric System. (AKA CLHPFLHRAMS.) Naturally, KaleCoAuto came to a partnership with them to create this finely machine crafted screwdriver. This screwdriver uses high tech materials, such as steel, and plastic. (NASA uses steel and plastic!) This screwdriver is great for loosening screws on the right side of the vehicle, or tightening screws on the left side of the vehicle."
The most useful tool is the WIPER BLADE SHARPENER.
"Wiper blades not cutting it? Why replace them, when you could sharpen them? This high grade whetstone is all that you would expect from our quality line of KaleCoAuto products. It features three sharpening surfaces for different
sizes of wiperblades."
I can get these at a discount, just send me a blank signed cheque (to save you the time filling in the details) to PO Box 000 in your nearest Capital City.
FollowupID: 672487
Follow Up By: Member - Fred B (NT) - Saturday, Feb 06, 2010 at 13:21
Here is the link to KaleCo Auto Elbow Grease
Thanks Tony, you are a gem. I take it you have personal experience in using these products?
Watch out the ModSquad don't get you for advertising..... lol... (:
Just kidding Modsuad... you do a great job.... (:
Fred B
FollowupID: 672488
Follow Up By: Wilko - Saturday, Feb 06, 2010 at 14:49
Thanks Fred/Tony.
I'll see if i can get some sent to me. Do i just apply the grease to the stain Or do I have to scrub it( I'm not to keen on doing effort lol
Cheers Wilko
FollowupID: 672497
Reply By: Roughasguts - Saturday, Feb 06, 2010 at 12:46
When I broke my elbow roller blading with my 8 year old several years ago, my elbow never fully extended or would ache constantly.
But 3 months ago I read some rubbish on uses for WD 40.... so I sprayed it on my elbow as mentioned it helps with old joints!! and it's been great since.
Try some of that on your elbows that will help.
AnswerID: 402950
Reply By: Tenpounder (SA) - Saturday, Feb 06, 2010 at 12:59
Hi Wilko.
I can't be sure, but I think the active ingredient in elbow grease is quite similar to Jiff. Certainly, i have had quite good results with Jiff and steel wool or other scourers.
The worst to remove are burnt in fat, which looks like a sort of varnish (rather than a blackish stain). This seems to need serious scouring, even to the extent of the Dremel with a wire brush. Lesser stains (more of the blackish food stuff etc), may respond to soaking in vinegar/bicarb soda mixture (sprinkle the bicarb soda, add the vinegar, leave overnight).
But basically, if you spread Jiff over the offending area, and then rub like billyo with steel wool until the sweat from your brow drips onto the steel, then you'll find the chemical composition will indeed be similar to elbow gease.
AnswerID: 402953
Follow Up By: Wilko - Saturday, Feb 06, 2010 at 14:52
Thanks Chris,
But i'm not to keen on putting any effort in to remove the stain thats why I'm looking for the original elbow grease.
Cheers Wilko
FollowupID: 672499
Reply By: Member - The Bushwhackers -NSW - Saturday, Feb 06, 2010 at 15:01
Hi Wilko,
While you are waiting for your parcel of elbow grease to arrive, try boiling water in the stainless steel pots, but cut up a few lemons first (or get someone to do it for you if it's too much effort), and put them in the pots. Boil it all up, leave it overnight to cool, see how ya go. Cleaned up a couple of kettles Mrs Bushwhacker wouldn't use... no elbow grease required!
Cheers, Dave
AnswerID: 402964
Reply By: john&thejayco - Saturday, Feb 06, 2010 at 15:53
Wilko,
I will look in the shed later ,there was some in there, i think it was on a shelf behind a stack of post holes that we dug once when it was wet so we didn't have to dig any when the ground got hard. Just near the left handed screwdrivers and motorbike ashtrays.
cheers, good luck with the search.
AnswerID: 402972
Reply By: Michael ( Moss Vale NSW) - Saturday, Feb 06, 2010 at 20:34
Forget the cleaning ,, time to get out more i think LLOL!!!
AnswerID: 402996
Reply By: D200Dug- Sunday, Feb 07, 2010 at 01:37
Stuff elbow grease
Use Esteel stainless steel cleaner
Much quicker and easier than actually scrubbing ;-)
AnswerID: 403027
Reply By: Wilko - Sunday, Feb 07, 2010 at 14:42
Thanks all for your advice,
SWMBO got it clean, she said she used a little bit of elbow grease, she must have had some under the sink. It is great she had some as I really didnt want to scrub it lol.
Cheers Wilko
AnswerID: 403106
