Ball weight help
hey all,
As i am looking for a caravan i have noticed the law has changed in regards to what i cantow, i was hoping someone could help me if the van is ok
The car i am driving is a 2005 mazda tribute V6 with a towing capacipty of 1600kg. Now i think the ball weight is 10% of that making it 160kg. is that right? ?
the van i am looking at is an imperial with a tare weight of 1390kg . how do i know the ball weight for this van? is there a formula to work to.
After ringing the towball compaines that install them they are trying to tell me i can only tow a ball weight of 90kg, that would only allow me to tow a bloody box trailer, that has to be incorrect dosent it? because even a windsor rapid has a ball weight of 115kg.
Please help as i am bloody confused....
thanks
Reply By: Tenpounder (SA) - Saturday, Feb 06, 2010 at 14:41
Hi Finny. First, the 10% figure (ball weight should be around 10% of the caravan weight) is, as far as I know, a rule of thumb, not a law.
Second, the loaded weight of a van with a Tare of 1390kg will be around 1700kg, which is far too much for your Mazda, whatever the ball weight.
Thirdly, the towbar company is quite entitled to manufacture a towbar which has a lesser spec than the vehicle. It sounds like you have purchased a towbar with am max ball weight of 90kg. The law says the allowable load is the lesser of (a) the vehicle manufacturer's rating; (b) the towbar rating and (c) the statutory limit.
I don't think the law has changed recently, finny.
Incidentally, I read last week that the Tribute share its auto transmission with the Ford Escape, and is prone to failure, especially when towing much over a tonne. If so, there's another reason not to overdo things.
AnswerID: 402960
Follow Up By: Tenpounder (SA) - Saturday, Feb 06, 2010 at 14:50
PS, the ball weight of the van you are looking at is NOT found using a formula - it is what the van actually weighs, after you have loaded it with your gear. Perhaps you are confusing max ball weights and actual ball weights? Lots of people add gas bottles on the drawbar, and bike racks on the van bumper (and lots in between) and this will certainly affect the actual ball weight.
So if you have a towbar max rating of 90kg and a vehicle with max towing of 1600kg, it seems that you are looking at a van with an ATM of 900kg or less, and thus a tare of say 700kg or so. Or, if you 'up' the towbar to the same specs as the Mazda, then you can theoretically tow 1600kg ATM (or tare perhaps 1200kg) with a ball rating of perhaps 150kg (Mazda specs will tell you the exact figure).
Does this help? It far from simple.
FollowupID: 672498
Follow Up By: finny - Saturday, Feb 06, 2010 at 14:54
thanks chris,
i havent yet got the towbar just looking into it all at the moment. When you say 1700kg fully loaded that seems like alot of extras to put in , or is that normal, i wouldnt be filling the water tanks as i would always use the parks, i know its touch and go but i rather investigate it know then been on the 6 o'clock news, your input is appreciated.
FollowupID: 672500
Follow Up By: Tenpounder (SA) - Saturday, Feb 06, 2010 at 15:10
My understanding is that often, the real empty weight of a van is well over the nominal Tare. Some makers 'guess at' the Tare at the design stage, and the actual depends of the details of your van, the extras fitted (type of stove, TV or not; microwave or not, Air Con, etc.) So the first thing to do is to find the real empty weight (as you say, no gas, no water, no personal stuff) with all the 'normal' fittings (gas bottle, spare wheel etc.), This will be the true Tare weight. Often, this will be more than 100kg above the nominal Tare (in you case, than, say close to 1500kg).
We carry around 200 to 250kg of stuff, by excluding TV, microwave, and by minimising clothes for 2. But we carry a fair bit of food bedding and other gear. Our van has an ATM of 1400kg (and a Tare of 1000kg) and we can keep the ATM under the 1400kg figure by careful juggling.
So you'll have an interesting time keeping the actual TM down to 1700kg to comply with Mazda's limits. I would suspect your Van has a stated (ie Max) ATM of around 1800kg.
FollowupID: 672502
Reply By: garrycol - Saturday, Feb 06, 2010 at 14:52
The tow ball weight capability of the vehicle is specified by the manufacturer. Therefore the max towball weight you can load up to is (as mentioned) the lesser of the manufacturers towball weight and the designed towball weight of your towbar.
The rule of thumb with respect to towball weight compared to trailer weight is that the MAX tow ball weight should be 10% of the weight of the van - ideally though the van/trailer should be loaded so that about 5% of the weight should be on the ball. The tow ball weight of the van can be adjusted by where you stow items.
Garry
AnswerID: 402961
Follow Up By: finny - Saturday, Feb 06, 2010 at 15:00
Garry, i just read an article about sway bars and weight distribution hitches, can this eliviate the problem i am having.
FollowupID: 672501
Follow Up By: Member - Teege (NSW) - Saturday, Feb 06, 2010 at 16:02
Garry
My understanding is that the downweight should be 10-15%. I would have thought 5% would be much too low. Have a look at the comments of the caravan guru Tom Olthoff in an inquest involving a caravan. Jong Inquest
teege
FollowupID: 672506
Follow Up By: Member - Graham H (QLD) - Saturday, Feb 06, 2010 at 17:26
Firstly there is no such thing as a MAXIMUM towball weight.
The figures quoted are suggested only.
There is no legislation governing this weight.
It is however governed by the manufacturers recommenation for the vehicle or the towbars limit whichever is the lesser.
A 5% towball weight would be downright dangerous on an Aussie built van.
No having a WDH DOES NOT allow heavier weights than recommended.
The towball weight is a constant and a WDH merely transfers some of the force on the rear axle forward to the front .
It does not alter the actual weight on the towball.
If anything some would say it increases the pressure by the action of straightening the joint.
The TARE weight of a van is inconsequential really Its the ATM you worry about,
That is the fully loaded LEGAL weight.
It should be stamped on the compliance plate on the van and should not be exceeded.
The Tribute according to a report in 4wd Action chews disc rotors rapidly on dusty roads and they are not cheap apparently
Something a bit heavier to tow with is advisable.
FollowupID: 672514
Follow Up By: Member - Graham H (QLD) - Saturday, Feb 06, 2010 at 17:38
The normal load allowance for a single axle van is 300kg.
This includes water gas and anthing not in it when it was originally built.
Eg we bought a van that had a palted Tare of 2154kg.
When I weighed it, it was 2300kg.
Had Aircon and two 30kg batteries and two solar panel added by prev owner.
Get the picture Weigh it before you buy it.
It should have 3 weights on the compliance plate like this
TARE 1045kg
GTM 1215KG
ATM 1345KG
The weights are
Tare DRY EMPTY weight
GTM the weight on the van axle when hitched up and loaded up ready to go on holiday.
ATM The weight on the axles and jockeywheel when in the above state
So mostly if you deduct the GTM from ATM you get roughly the ball weight
which will vary depending on how you pack the van.
FollowupID: 672516
Follow Up By: jabiru340 - Saturday, Feb 06, 2010 at 20:39
Teege
That Jong Inquest was a very interesting read.
I have noticed some tandum wheeled caravans swaying a bit at speed, obviously from Mr Olthoff comments the tow ball weight was too low.
I have a single axle trailer with a tow ball weight of 10% and use WDH and an anti sway bar. The anti sway bar completely eliminates the draw that can occur when a large truck overtakes and also eliminates any sway caused by strong cross winds.
I have a friend who recently purchased a new tandem van and no matter where he placed items in the van could not get the towball weight to get past 5% so he was getting a bit of sway. From Mr Olthoff's comments it was caused by too little tow ball weight.
He went to hayman reece and had 2 anti sway bars fitted as recommended by them, he tells me that it made a big difference to towing and completely eliminated any sway.
FollowupID: 672529
Follow Up By: Member - Graham H (QLD) - Saturday, Feb 06, 2010 at 20:54
If your friends van is an Aussie made van and not an Adria or similar I would be taking it back to the dealer and finding out why it is only 5%.
It is far to low and will make it unstable.
Has he done the usual and added toolboxes or anything on the rear bumper.
I would certinly not tlike to tow any van with as light a ball weight as that.
My new van is a 25ft and weighs 2853kg and has a towball weight of 300kg.
Adding anti sway bars is like putting an ambulance at the bottom of a cliff.
It patches up the accidents but doesnt treat the problem.
He should be looking at why and get it adjusted rather than bandaid solutions
to fix an inherent fault.
I dont have antisway bars and even at that size trucks dont really bother me and I have been on a 45,000km trip this past year, much of it in roadtrain territory.
FollowupID: 672530
Follow Up By: Trevor R (QLD) - Sunday, Feb 07, 2010 at 09:16
Graham, spot on mate. I have towed many hundreds of thousand kms with a few vans + trailers (you could say I done it commercially) and never felt the need for WDH. It can take a bit of planning and trips to the weighbridge but when it's right it will make a big difference to the towing pleasure of the driver. Do not accept van manufacturers guestimates, get it to a weighbridge and find out what the weights really are for yourself.
Regards, Trevor.
FollowupID: 672549
Follow Up By: Trevor R (QLD) - Sunday, Feb 07, 2010 at 09:21
Graham, the last bit of advice I offered was for finny. I know you already would have known this anyway hehehe.
Trevor.
FollowupID: 672550
Follow Up By: Member - Graham H (QLD) - Sunday, Feb 07, 2010 at 09:37
Yes I know but I do use a WDH as should anyone towing a van of much over 1000kg.
Whether they think its loaded correctly or not.
FollowupID: 672552
Reply By: escapesilv - Saturday, Feb 06, 2010 at 15:24
Hi Finny
I have the Ford version, and tow an off road camper weighing 650 Kg. empty, so when totally loaded I am aprox. 900 Kg.( not including water.) at that weight I have not had problems with gear box, or any other part.
We have towed aprox. 70.000 Km with this car, and some times I must admit we have been over the 1000Kg.
I personally think it will be a bit of a strain if you are towing 1600 Kg. and remember you still have to stop it.
Just my 5C.
Regards Robert.
AnswerID: 402967
Reply By: john&thejayco - Saturday, Feb 06, 2010 at 15:35
hi finny,
Site Link Try this it helped me when i was looking at another tow vehicle. this was given to me by someone else on this forum and it has helped me,if you are looking at a genuine mazda towbar it should answer your question.Cheers.
AnswerID: 402969
Follow Up By: john&thejayco - Saturday, Feb 06, 2010 at 15:38
finny,
if the site didn't come up,you can try to google "romacaravans tow mass guide". cheers.
FollowupID: 672504
Follow Up By: finny - Saturday, Feb 06, 2010 at 16:45
thanks for the info, john i nwill check it out now thx, due to everyones opinion i might just have to upgrade to that Toyota Hilux i have been at the Mrs for...lol wish me luck
FollowupID: 672508
Follow Up By: Tenpounder (SA) - Saturday, Feb 06, 2010 at 17:13
Nah, finny, luck's got nothin' to do with it. Take your wife on a REAL camping trip, in a nice, comfortable 3 man dome tent for a week, preferably moving every day, with weather between humid to wet, warm to freezing, and then say how this is really perfect for you, no need to even think about upgrading. Make sure the airbeds have a leak, and take sleeping bags that are not quite up to the mark.
THAT's when the caravan starts to appeal!!
FollowupID: 672512
Follow Up By: finny - Saturday, Feb 06, 2010 at 17:38
tenpounder !! !! now thats a bloody fantastic idea if i've ever heard one....!!!
FollowupID: 672515
Follow Up By: Gazal Champion - Sunday, Feb 07, 2010 at 13:47
Tenpounder you are a devious fellow! LOL
FollowupID: 672593
Reply By: fugwurgin - Saturday, Feb 06, 2010 at 21:08
I was just wondering how people weigh their actual towball weight? do they just whack it on a good set of bathroom scales?lol i want to weigh my camper trailer, any suggestions?
AnswerID: 403004
Follow Up By: Nomadic Navara - Saturday, Feb 06, 2010 at 22:18
The only accurate way is to take your van to a weigh bridge. Remove any WDH before you approach the bridge. Drive across the bridge so your tug is clear of it. Ask for and note the weight. Then raise the coupling so it is clear of the ball (no need to uncouple the chains or trailer plug.) Note the weight. The ball weight is the difference between the two weights.
It is no good doing this unless your van is loaded for a typical long trip. I recommend this as being the only way to go as it also checks to see if your van is overloaded or not.
FollowupID: 672536
Reply By: Nomadic Navara - Saturday, Feb 06, 2010 at 22:11
Finny
For starters you should be looking at the ATM of a van you are considering rather than the tare weight. Then you should consider the fact that many vans weigh heavier than their plated tare weight. The ATM of most single axle vans is generally specified at tare plus 300 kg, dual axle vans are plus 400 kg. hower some like Jayco add the weight of the water in the extra tank supplied in shower models.
There is legislation regarding ball weights. It states that the ball weight of the trailer must not exceed that specified on the tow bar or the tug manufacturers specification - which ever is the lesser. The ball weight on a vans compliance plate is only that as delivered unloaded, it has nothing to do with law or the weight that you have after loading - the only legislation is covered in my second sentence of this paragraph. The ball weight or your van when you load it depends on how you load it - not what is on the compliance plate.
Regarding caravan ball weights - these depend on how the van is built. European vans are deliberately designed and built with minimum weight at the ends, that's how they can be stable with 5 - 8% ball weight. Oz vans are not built with that philosophy, they have heavier front and back ends and thus require 10% plus ball weights. Those who add boxes and jerry cans at either
ends should be looking at 15% ball weight. This link describes how it works.
Regarding the use of WDH. Many manufacturers specify that WDH or Load Level Hitch Required. My info is that Mazda require you to use WDH. This one would be suitable for your application.
"finny posted:
"Garry, i just read an article about sway bars and weight distribution hitches, can this eliviate the problem i am having." - If the article you are referring to is one published in C & M stating that WDH reduces the ball weight, I suggest you take little credence to it. Legally the ball weight of a van does not change (unless you use a sky hook.) This article has been discredited by other experts and seen as BS by others.
I agree with you about twin cabs. I use a D40 Navara as my tug. It allows you to carry comfortable chairs plus other bulky items and you are not constricted to carrying those uncomfortable umbrella chairs. You can make yourself at camp sites if you can carry bulky items in the back of the truck rather than limiting yourself to smaller items that will fit into the boot of something smaller.
AnswerID: 403014
Reply By: finny - Sunday, Feb 07, 2010 at 08:43
Wow all of the responses are alot more informative that i get from the sales yards, I think i am safer just to go with the hilux option as for what i want the tribute might not handle it as well as i thought.Now i realise why i like this website so much.
i will keep you posted about trying to talk the Mrs into that hilux....
AnswerID: 403040
Reply By: ozjohn0 - Sunday, Feb 07, 2010 at 08:55
For the 2005 Tribute, Mazda state the following:
Max Tow Weight 1600kg
Ball weight 10% of tow weight to a max off 160kg.
A WDH must be used.
The van you're looking at will be to heavy for the Tribute as it's ATM will exceed 1600kg.
ozjohn.
AnswerID: 403042
Reply By: finny - Sunday, Feb 07, 2010 at 17:22
well after showing the Mrs the imperial she agreed to get the beloved Hilux, so it's a win win allround. So with the hilux's specs i am sure to have enough weight to play with.
AnswerID: 403124
