Nissan Hand Throttle
Submitted: Saturday, Oct 04, 2003 at 03:18
10 Para
Any know if you can fit a hand throttle to a nissan gu, would come in handy at times.
Reply By: Bonz (Vic) - Saturday, Oct 04, 2003 at 10:03
What engine? If its a drive by wire unit then you're out of luckLaterally Literal
Seriously Cerebral
32751
Reply By: JohnR - Saturday, Oct 04, 2003 at 15:08
Think Bonz is right. My 4.2 TurboIntercooled is already fiited with one. Really only need that if you have a PTO drive for anything or perhaps for the low range box. Cruise control is much more useful
32761
Reply By: Mick - Sunday, Oct 05, 2003 at 13:47
Dont pull the throttle control on whilst driving,
mine broke when i pulled it on, and got stuck on full revs. Not Good!!
32812
Reply By: chrisfrd - Monday, Oct 06, 2003 at 22:33
My 3.0 now has one! I filtched a 4.2 hand controller from a wreck. I made up a cable to take the input to the hand controller down the throttle actuator mounted on the floor, wrapping it around the wire bail, the same as the existing throttle does.
This works like a treat and gives me revs up to 1500 RPM. I use
mine in the freezing
Canberra mornings to heat up the car/transmission, by starting the truck, selecting N on the t-case and putting the car into 3rd.
On the turbo-timer the truck will run for 10 minutes and then re-imobilise. Nice!
32934
Reply By: woddonnee - Wednesday, Oct 08, 2003 at 00:24
G'day
I recently had an autron auscruise cruise control fitted which could be used as a hand throttle. This is done by putting it in test mode, ie hold the top (set/acc) button down while you turn on the ignition. Then, turn it on and use the acc and dec buttons to adjust revs. Press cruise off to quickly go to idle.
Rod
33078
