AnswerID: 32876 Submitted: Monday, Oct 06, 2003 at 13:20
Member - DOZER
replied:
Gday
Diffs from a 78 series will fit in easily with 4wdiscs. If you bought a writeoff, it would most certainly come with a 1hz/5 speed that will go in fairly easily aswell.
If not your preferance, keep an eye out for a 12ht from a turbo 60 series, it should go straight in being a 2h block, same again if you buy a writeoff, you may get the 5 speed aswell plus wiring harnesses etc. This is the cheapest way to retrofit as you can make your $$ back from spares. Check out www.pickles.com.au
Andrewwheredayathinkwer mike?
Reply 5 of 5
FollowupID: 23513 Submitted:
Monday, Oct 06, 2003 at 14:03
robert4615 posted:
peter, thanks for the info. where can i purchase the 1HZ diesels at this price? tel#'s ,websites, any info will be appreciated. regards, robert
