GQ PATROL GEARBOX -
Submitted: Sunday, Oct 05, 2003 at 18:49
ThreadID: 7620 Views:1997 Replies:3 FollowUps:2
Question relating to Post ID 2470 (posted 26/11/02 by BB)
Did you ever sort out the vibration in the gearbox from idle to 1200 rev's - if you did, what did you do?
I have a similar problem in my 91 GQ diesel.
gq42
Reply By: colin - Monday, Oct 06, 2003 at 17:06
you wont get rid of the vibration as its a trait of 4.2 diesal GQ, the motor is being laboured which causes the vibration just give it a touch more throttle and it goes, all 4.2 do it, i solved 95% of the problem by fitting a super charger which gives more low down torgue but this is an exspensive way to solve a problem which will do no harm to youyr vehicle, mine has done 260,000ks and had no drive line problems. Try taking a similar vehicle from a car yard for a test drive and compare. Col
AnswerID: 32895
Follow Up By: gq42 - Monday, Oct 06, 2003 at 19:03
Thanks Collin will give it a go and see what they sound like.
gq42
FollowupID: 23519
Reply By: Mick - Wednesday, Oct 08, 2003 at 09:03
I sold my shortie at 500k, i bought it at 350k the noise was there when i bought it, and the noise was there when i sold it! And i treated it like hell in all the 4x4 competitions in sydney!
AnswerID: 33093
Follow Up By: gq42 - Wednesday, Oct 08, 2003 at 19:08
Thanks for that Mick if I get the same type of k's out of mine I will be
a very happy man.
gq42
FollowupID: 23727
Reply By: nissan - Tuesday, Nov 04, 2003 at 15:13
HI,
LIVING IN OUTBACK QLD I'VE HAD 3 4.2D GQ'S AND 1 GU 4.2D AND ALL OF THEM HAD THE VIBRATION AFTER ABOUT 80000 KM. THE PRESSURE PLATE ON THE FLYWHEEL WAS UNBALANCED FROM A MIXTURE OF BULLDUST, CLUTCH DUST AND WATER BUILDING UP IN BETWEEN THE COVER AND THE DIAPHRAGM SPRING. THIS EVEN CREATED A NO DRIVE SITUATION ON ONE GQ CUTTING ACROSS FROM BEDOURIE THROUGH THE DIMANTINA LAKES NP AFTER 11 INCHES OF RAIN. THE DIAPHRAGM SPRING COULD NOT RETURN PROPERLY TO APPLY ADEQUATE PRESSURE TO THE CLUTCH PLATE. ALL I DO NOW WHEN I GET THE VIBRATION IS REMOVE THE BOOT WHERE THE CLUTCH RELEASE ARM GOES THROUGH THE BELLHOUSING AND UP IT WITH THE HOSE WHILST SOMEBODY CYCLES THE CLUTCH.
AnswerID: 36192
