Downloadable pajero service manual
Submitted: Wednesday, Oct 08, 2003 at 20:30
hoopsville
I need to replace a noise lifter in a 92 3.0 V6 pajero.
Does anyone know where I can access a downloadable pajero service manual from?
Any replies greatfully accepted.
You can post or email me direct at kennethhooper@hotmail.com
Ken
Reply By: Martin - Wednesday, Oct 08, 2003 at 21:29
Ken if you can't get one just let it be noisy - it's a very common Pajero failing and won't cause any damage.
33182
Reply By: crfan - Thursday, Oct 09, 2003 at 09:51
Have you tried pooring in a bottle of lifter free about $12.00 a bottle worth a try first.
33214
Reply By: hoopsville - Thursday, Oct 09, 2003 at 22:43
Any brand of lifter free better than the other?
33289
Reply By: Groove - Thursday, Oct 09, 2003 at 23:15
I had the same problem for years in My 3l Pajero and my mechanic kept telling me not to worry about it, I was never comfortable with it but it never caused me any problems.
33293
Reply By: Eric Experience. - Friday, Oct 10, 2003 at 10:56
Hoopsville.
Ken you don't have to remove the lifters to fix them just push a 1mm diameter piece of steel wire into the oil hole in the rocker imedietely above the lifter, with the motor running the oil will flow out as you push the ball of its
seat and clear the grit which is causing the problem. Change you oil more often. Eric.
33321
Reply By: Simon - Sunday, Oct 12, 2003 at 22:18
try here.
http://www.mitsubi bleep echinfo.com/epacarb/default.jsp
33527
