LPG bottles - laying on side
Submitted: Wednesday, Oct 08, 2003 at 22:01
rodeoowner
I haven't visited for quite a while and just read an old post on laying LPG bottles on their side.
This is a major no-no. It has nothing at all to do with the rubber seals etc. The PRV (pressure relief valve) is at the top of the cylinder. In the event that there is a major pressure build up (usually from over filling or extreme heat) the PRV will release and gas vapour will come out until the pressure has dropped back down to an acceptable level. If the bottle is laying on it's side the PRV is in the liquid section, not the vapour. If there is a major pressure build up the vapour cannot escape through the PRV. The PRV will not activate and the only way out for the vapour is through the side of the cylinder, that is, it will explode. This is known as a BLEVE.
Legally the amount of LPG that can be stored in the passenger compartment of a vehicle is 25.4 litres. There are approximately 2 litres to every kg of LPG. This is set out by the Australian Dangerous Goods Code. There used to be a ruling in AS1596- Storage and Handling of LPG which stated (from memory) 2kg. This was taken out in 1996 (from memory). To me, personally 25.4 litres seems crazy. I wouldn't carry any inside a vehicle if I could help it. You can buy plastic plugs to screw into the cylinder valves from
camping shops.
Hope this helps.
Reply By: Member - Geoff & Karen - Wednesday, Oct 08, 2003 at 23:45
It's actually bottles of 2kgs or less may be transported inside a vehicle. not 25.4 litres.
KarenKind Regards
Karen & Geoff
(Happy holidaying)
33200
Follow Up By: rodeoowner - Sunday, Oct 12, 2003 at 16:23
Hey Geoff & Karen, from memory you guys own/run a gas company? Where do you get the 2kg limit from? My info comes from the Australian Dangerous Goods Code. AS 1596 makes no mention of it. Not trying to be a smart alec, I genuinely want to know. I read some of the uninformed info on here about LPG and it frustrates me to hell. Just for the record I am a gasfitter and have worked for various gas companys for the past 10 years.
24033
Follow Up By: Chris (W.A.) - Sunday, Oct 12, 2003 at 19:44
I would like to know the chance of one going off inside a car. You'd probably have a better chance at winning first division lotto.
I'm more worried about the fuel tanks than the gas bottle.
Nice southerly coastal fishing trip someday.
Chris
24043
Reply By: Truckster (Vic) - Thursday, Oct 09, 2003 at 10:09
Actually a BLEVE is a Boiling Liquid Expanding Vapour Explosion usually caused by heat. Excess pressure and excess heat are 2 different things with this. There are some good vids available on BLEVEs, done by NSW Fire Service, we used to use these for training courses we ran.
Basically they both rely on the Relief Valve to vent, but are actually different. As it says one is caused by heat expansion, one is caused overfilling pressure.
Also knows as Bloody Loud Explosion Very Exciting, specially if you have been there when one happens. :)
Also in reality carrying a 24 ltr gas cyl inside or out (Roof Rack) of your car is going to almost certainly end in the same result...
33217
Follow Up By: rodeoowner - Sunday, Oct 12, 2003 at 16:26
Not trying to be a smart alec Truckster, but when LPG is in the cylinder it is boiling. When you raise the pressure, the boiling point lowers. Excess pressure and excess heat may be different things, but they are closely related. When LPG is heated, the pressure rises, in turn causing a BLEVE.
24034
Follow Up By: Truckster (Vic) - Monday, Oct 13, 2003 at 22:30
You can have excess pressure without heat though... Which isnt a BLEVE.
24184
Reply By: Member - Alex B - Thursday, Oct 09, 2003 at 11:03
I was once told by an experienced safety instructor that the correct STEPS to take in the event of a LPG gas leak were “BIG ONES AND PLENTY OF 'EM!!” :-)
Alex
33223
Reply By: Member - Geoff - Thursday, Oct 09, 2003 at 12:31
Can I ask the obvious question to me that is "why do most
fork lifts powered by LPG lie on their sides ??.
Cheers Geoff.
33227
Follow Up By: Old Jack - Thursday, Oct 09, 2003 at 14:49
the
fork lift cylinders have the relief valve fitted to the end and have to be placed with the valve to the top most point when installed. they are filled so that when standing up or laying on there side the vent valve in above the liquid level. these cylinders are filled to about 80% of there
water capacity leaving expansion space.
safe motoring
Jack
23799
Reply By: Member - Wherethehellawi - Thursday, Oct 09, 2003 at 18:30
If I am not mistaken the pressure relief valve should relieve excess pressure wether it be vapour or liquid. the prv is to stop an explosion and it does matter if the cylinder is upside down on its side or standing up. It has to be fail safe to prevent the explosion due to excessive presures.
If they had to be standing up it would be marked all over the cylinder and also clearly marked. It scrap that a cylinder must stand up to allow the safety valve to operate.
They use similar prv valves in refrigerant cylinders and I have seen one go off when on its side due to over filling.
Boc gases do not use the bleed method of refilling cylinders but rather they weigh. If a cylinder is cold it can accept more liquid gas without being immediate dangerous. But when the cylider warms up its a different story. If over filled the contents are fully saturated and can be considered to be all liquid. The prv will release at the presure it is designed to go off at. It does not matter if its vapour or gas.
I may stand to be corrected but I think its baloney that the cylinder must be upright to allow the SAFETY valve to go at its designed setpoint!.Wow! am I cute
If yer ain't fishing, Yer ain't livin
Richard
33261
Follow Up By: rodeoowner - Sunday, Oct 12, 2003 at 16:31
Hey. Gas cylinders are filled by two different ways. Bottles 9kg and lower are filled using the bleeder valve. When the cylinder reaches 85% capacity the liquid will come out of the bleeder valve. Then you know it is full. Cylinders over 9kg are filled by weight.
If the PRV opens and liquid comes out, you will get 270 times the amount of gas out, rather than if it was vapour.
24035
Follow Up By: Member - Wherethehellawi - Monday, Oct 13, 2003 at 08:11
non the less,
the prv will open at the set pressure and relieve the the presure on the cylinder.....Whether its upside down or not!!
(BOC only use the weigh method as their cylinders Do Not have a bleed valve.)
And the contents of a static liquified gas cylinder is not boiling. It only boils when the presure is reduced in some way. Wow! am I cute
Richard
24064
Reply By: johnsy - Saturday, Oct 11, 2003 at 11:27
1 lte of lpg under pressure will expand 270 times =270 c metres .
heavier than air so will pool in low areas
be careful try and keep it out of the cabin at all costs
33419
