Nissan Patrol Questions?????
Submitted: Friday, Oct 10, 2003 at 15:04
swbpatrol
Gooda
Im currently pulling my TB42 to replace it with a TD42. I understand
the gearbox will bolt up but i need to tap a third hole for the
starter motor but what i need to know will the clutch i have on my
TD42 still be used in the TB42 Bellhousing????? Also should i get an
auto sparky to fix the current wiring or should i get a whole TD42
wiring harness???
Chris
Reply By: Truckster (Vic) - Friday, Oct 10, 2003 at 21:22
Call wrecker and get price on a harness, then call autospark and get a quote..
33389
Follow Up By: Truckster (Vic) - Friday, Oct 10, 2003 at 22:03
PS. this has been talked about on the Patrol list and here before, the Christie Bros, are gurus at this conversion, specially Pete.
Contact him on the Patrol4wd list on Yahoogroups.
23965
Reply By: Eric Experience. - Friday, Oct 10, 2003 at 21:45
Chris.
To do the job properly you will need to get a loom and a instrument cluster plus the ignition switch and the three relays and glow plug controller, its best if you can get the whole lot still plugged together as even a good auto elec will have trouble if he has not got a factory cct. Note the alternator and regulator are also different, thereticly you should have a larger vaccum storage
tank. I recomend trading the petrol in on a diesel it will end up cheaper and better. Eric.
33390
Reply By: Mick - Saturday, Oct 11, 2003 at 09:31
If you do get a TD42, make sure you get it complete with starter, alternator and flywheel, as both flywheels are different.
Gearbox input shaft spline is the same, but cant remember about the clutch mounting to the flywheel. Should be the same, but dont quote me.
If your going to do it, definitely get a wiring loom, its not hard to fit, as all plugs on the electricals are the same - eg. wipers, heaters, lights etc.
You will need an instrument cluster, I have a spare if you cant find one.
The dash has to be removed to fit the new harness, dont worry this is only a 1 hour job.
The starter bolt has to be drilled and tapped into the gearbox, as you know.
Give me a call for any other assistance
Mick Christie 02 9620 1208
33413
