radio mount
Submitted: Monday, Oct 13, 2003 at 17:51
uppy
Hi everyone,need some advice,Ive got a older phillips uhf-cb radio .Its about A4 size and about as thick as a country phone book.Im thinking of putting it on top of the dash.
Well it get to hot there,i dont know anything about radios
regards uppy
Reply By: Member - Bob L - Monday, Oct 13, 2003 at 19:46
Hi uppy.
I cannot recommend mounting the Phillips or any other radio for that matter in direct sunlight as the extreme heat will only lead to dry joint problems later on. Also any plastic will become deformed.
My 50watt vhf rig is on the centre console and gets very hot even when covered up. ie sola tint and sun shades.
See you next week.
Bob L
33641
Reply By: jo - Tuesday, Oct 14, 2003 at 14:37
Hi Uppy,
I'm just installing an olde UHF myself too,
I was thinking of screwing some brackets to hang it under the front console/dash (got a HJ47 cruiser so the added mess will look just fine)
but then the leg room is a bit more constricted
so
Now I am going to make a simple bulkhead up above the windscreen, you can get fancy ones fitted for over $100, I'm just thinking of getting a length of ply which can flex enough to bend it into
the gap above the front section of door frames and then flatten out in place.
Then the UHF can go there, screw the handpiece thingy holder on up there too, then there will be extra storage room for maps etc up there. Should work even for big old radio contraption like yours, if your vehicle has suitable ceiling situation.
Probably will have to make a bit of an edge to stop things crashing down on all those bumpy tracks.....
jo
33739
Follow Up By: uppy - Tuesday, Oct 14, 2003 at 20:24
Thanks Jo , the problem with your idea is that i dont have the room for that size radio on the roof ,Bob l is going to install it on Friday on the side of the central console on the wifes side , she got small legs. Thanks for the time to reply,and say in touch
regards uppy
24266
Reply By: Slammin - Wednesday, Oct 15, 2003 at 23:01
No room under the radio, thats where my bleep ty od still working phillps went!
33975
Follow Up By: uppy - Thursday, Oct 16, 2003 at 08:54
Thanks Slammin, we
well look at that on friday ,
well let you know how we get on
regards uppy
24470
